Inverted Pendulum - Creative Programming!
Check out this new video of a linear actuator used as an Inverted Pendulum!
Click Here! This is a great example of programming. |
Re: Inverted Pendulum - Creative Programming!
Cool video!
I spy some banebots parts. |
I see the wheels, anything else?
I'd love to see the program on that |
I'm guessing it's a rather untuned PD controller. Inverted pendulums can be controlled pretty stably if you use even just PD. X-travel targeting can be accomplished by adding in the Integral.
We did this in my controls lab. We used LQR and PID control (though the manual only lists LQR). There's some good math behind it all though. The lab does discuss adding in an Integral controller though. https://engineering.purdue.edu/AAE/A...11/lab3/manual These labs were always scary because we had to calculate all of our gains prior to actually testing and we had to put our gains to the test in lab (only 1 chance to get it right) Last edited by Michael Hill : 28-10-2014 at 18:15. |
This is the version we used: http://www.quanser.com/products/linear_servo_IP02 |
They have a similar device at the Ann-Arbor Hands on Museum. However, the pendulum is supported from a swing - arm that travels in a circle. That way it's not on a linear track and you never run out of track to balance on.
Mmmm, dat PID control loop. Love this stuff.
Something tells me there is a little more than just a PID loop in there
But, the PID loop is very well tuned. Probably running insanely fast too |
#10
More info here. http://www.youtube.com/watch?v=KOLRu7z-Gnk
#11
