Go to Post Batteries don't help you if they're lying on the field. - Kevin Sevcik [more]
Unread 29-10-2014, 00:20
Deke's Avatar
Deke Deke is offline
no team (No Team)
Rookie Year: 2013
Deke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the rough
pic: Concept 6W Drive Train
Unread 29-10-2014, 00:21
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Rookie Year: 2007
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Re: pic: Concept 6W Drive Train
Any particular reason for cutting off the corners? Does it help much in giving more area for a given perimeter?
Definitely have to concur that simple is good.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 29-10-2014, 00:23
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Rookie Year: 2013
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Looks solid.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 29-10-2014, 00:51
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Looks a little too solid IMO. There's a ton of 1x1 on there.
However, 34 lbs is still pretty light for six cims (actually that's very light) so adding in a shifting gearbox would make good use of that drivetrain I think. It's only a couple pounds more, and allows for safe top speeds of 18fps+ without worrying about main breaker trips.
Unread 29-10-2014, 01:00
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
What makes this drive train better than a kitbot with nitrile treads and 6 cim gearboxes? If you want to keep it simple why not go that route?
2014-2015: FRC 865 Warp7 Team Captain
2016: FRC 865 Mentor
2017: Free Agent Mentor, Inspector
Unread 29-10-2014, 01:04
Andrew Lawrence
Posts: n/a
How is that any simpler than this?
Unread 29-10-2014, 01:13
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
It's not.
Unread 29-10-2014, 01:21
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
Oh I just noticed:
Your main gearbox shaft is attached to the out frame member. If the outer frame becomes damaged in a collision and bends a little, it will damage the efficiency of the gearbox, and possibly render you immobile on one side.
Also, what's the reasoning behind cutting the corners? It seems like extra work to me.
Unread 29-10-2014, 01:34
EricH's Avatar
EricH EricH is online now
New year, new team
FRC #1197 (Torbots)
Originally Posted by AdamHeard View Post
It's not.
They are trying to work within their existing resources, and this is a simple design that fits within those resources. I would probably find it reasonable to assume that they don't anticipate having the funding to buy Versa, or to buy Versa and still do X, Y, and Z that they want to or need to do. Or that they're one of the teams that prefers making over buying (there are a few out there).
Is a WCD simpler? Maybe. But if you're doing all the machining for it, there are some advantages to NOT doing a WCD (like having more time!). Even if you are thinking of buying one, there could still be advantages to not doing one (dead-axle setups tend to be a trifle easier than live-axle setups in terms of manufacturing, something about no keyway or hex).
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 29-10-2014, 01:42
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Rookie Year: 2012
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
Are the gussets at the corners supposed to be seperate strips or angle iron? If they are seperate strips, it looks like a hard hit to the upper member could severely bend it inwards.
Edit: The upper 1x1 above the wheels
(2015-?): 973
(2012-2015): 955
Unread 29-10-2014, 01:44
Andrew Lawrence
Posts: n/a
A full versachassis can get expensive, I'll admit that, but just using some of the parts can greatly simplify this design and make it not only more effective, but more reliable as well. You don't need to buy an entire drivetrain setup, but using what your resources will allow can greatly simplify things.
You don't need to break bank on COTS parts to make a great drivetrain, but ignoring the cost effective resources available to teams isn't the answer either.
Unread 29-10-2014, 02:02
T-Dawg's Avatar
T-Dawg T-Dawg is offline
Team Manager
AKA: Alan
FRC #0955 (CV Robotics)
Rookie Year: 2013
T-Dawg is an unknown quantity at this point
Is there a particular reason why the corners of the chassis are cut off?
The only reason I can think of is if you're trying to make the chassis fit within the 112 inch frame perimeter.
Otherwise, I don't see a structural benefit of cutting the corners off.
Unread 29-10-2014, 02:14
Spoam's Avatar
Spoam Spoam is offline
AKA: Pedro M.
Rookie Year: 2012
Spoam is a jewel in the roughSpoam is a jewel in the roughSpoam is a jewel in the roughSpoam is a jewel in the rough
Otherwise, I don't see a structural benefit to cutting the corners off.
If I had to guess it would be that they're trying to keep all the 1x1s the same length for convenience? Then cut ends to keep it flush. Personally though if that's it then I might rather have the extra support from corners.
Unread 29-10-2014, 17:52
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
BrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond repute
I smell no bias here. Nope.
WCD and even the Versachassis is not the answer for every team.
1519 Mechanical M.A.Y.H.E.M. 2008 - 2010
3467 Windham Windup 2011 - 2015
1058 PVC Pirates 2016 - xxxx
  #15   Spotlight this post!
Unread 29-10-2014, 06:32
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
(nvm)
