Re: Gearbox for mechanism or appendage
Hi All,
I did some measurements and testing on the gearbox, particularly on the 168:1. Weight came to 1.1lb (0.5 kg) Backlash was 1.1 degrees Efficiency was a bit trickier. I have a supply that has 3 different power settings and a very course amperage meter. I put a volt meter across the leads when I ran with a bare motor and then retested with the gearbox (no load). I did this with 2 different motor / gearboxes and in both directions. The voltage across with the gearbox was around 9, 12, and 14 volts, so I think the efficiency was hurt a little bit by spinning faster than what would be seen in normal operation. Without putting a ton of data down, the average of the results for efficiency under no load came out to be 61%. All but 2 of the results were +/- %7 from this. I would expect that the values for the 264 and 552:1 should be very similar to the above. Next up, making an adapter plate for a torque wrench to test max torque. |
If you could build in a FIRST standard bolt pattern, we could attach sprockets! D |
500:1 is probably a bit slow if the plan is to mate it to a CIM motor. At free speed, it would go down to 9 RPM or about 7 seconds per revolution. At peak power, it would be about 13 seconds per revolution. An arm sweeping 120 degrees would be between 2.5 and 4 seconds which would seem pretty slow.
The 125:1 & 250:1 arms have me pretty intrigued. Are you measuring efficiency as "Actual speed / theoretical free speed"? Richard Wallace and some others might be able to help you with a more accurate efficiency method that you could do. A string and spool winch with a weight and stopwatch could probably be pretty effective way of measuring efficiency at several torque levels. |
Isaac is right, a string, weight, spool, and stop watch are the best method for this kind of measurement when speeds are low; e.g., when it takes several seconds for the weight to drop.
On the original topic, I recommend this lugnut remover as cheap example of cycloidal gearing. It was easy to find at Harbor Freight years ago. Don't know if you can find it there now. I posted some details and pictures a few years back, linked earlier in this thread. |
