pic: Team 2950 Devastators WCD
Re: pic: Team 2950 Devastators WCD
Looks very nice but I would have to say two things. First being that you are probably going to want to support the face of your gearbox more, you do not want that twisting to torquing. Second I love the milled team name, don't get me wrong, but it will just get covered by the bumpers and now you have just made a weaker beam for something most will never see. Just my $0.02 but overall it looks very nice.
Nice WCD.
A suggestion. Those bumper mounts will be very low. you will only get about an inch of actual material behind the 5 " bumper. We built a very similar drive last season. http://www.chiefdelphi.com/media/photos/39228 A lot was changed internally but the frame shown is basically what we built. Luckily the upper frame that held our pick up and catapult provided addition backing to the upper portion of the bumper. Something to think about. Other wise a great iteration, looking forward to more. |
If you guys would like any help with Solidworks feel free to message me, I would be more than willing to help.
We did a very similar drivetrain in 2013 (so much so that we had the tube between the wheels, although ours was 8 wheel drop) and had a horrible time with warping and flexing. We actually weren't able to drive in a straight line towards the end of it's life. In 2014 we moved back to our beloved 6 wheel drop and added a top structure. It has been the most solid frame we've ever built just because of the second structural layer.
Last edited by theawesome1730 : 02-11-2014 at 12:14. Reason: Autocorrect evaded me. |
Happy to see your SOLIDWORKS model.
You can take a look at the Blue Cheese model we redid at www.solidworks.com/FIRST Dividing into subassemblies will help you in organization. Also, download our revised 2014 kop. Use Add File Locations in SolidWorks Resources and browse to the downloaded components to see the all the models that we have created. Here are some tutorials to help https://www.youtube.com/watch?v=ogKY...W-gEKDxfWgShwG There are many people on CD that are very knowledgeable on SOLIDWORKS. Well done- keep modeling. Marie |
![]() Here is an image of our 2014 WCD As you can see, there are two levels with bracing and gussets in between. The lower level is very similar to the chassis safiq10 posted but with the addition of the top level we have achieved greater stiffness and resistance to torquing and flexing that a single layer is prone to. The second level additionally provides a good area for bumper mounting. |
I don't remember specifics but without wheels and hardware and 3 CIM ball shifters I believe we sat at about 20lbs
#10
Thanks to everyone who has helped us out so far! Here is our updated CAD and here is a rendered picture of it. We believe we are nearing completion but we would like the advice of the CAD gurus on CD. So what do you guys think? Is there anything you think we should change?
#11
It looks like you are using shaft collars to old the wheels on. I would strongly encourage not doing that. Use e-clips, snap rings, or bolts threaded onto the end. shaft collars will slide off almost immediately. Other then that, it looks like a great start.
#12
Thank you for all the kind words and advice! This is our very first time working in Solidworks we greatly appreciate all the advice. To address some questions
