Go to Post FIRST: there is no second. - BandChick [more]
Unread 04-11-2014, 00:16
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Re: pic: MOEnarch Swerve Drive
Originally Posted by Ether View Post
Here's why:
+1. That kind of reduction will result in an extremely low speed, around 5 fps according to JVN design calc. Not really worth a 4 cim 4 minicim drive IMO, as even in high gear mecanum you're only running 12fps...
Unread 03-11-2014, 16:19
Adrian Clark Adrian Clark is offline
FRC #1678 (Citrus Circuits)
Adrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the rough
Originally Posted by nathannfm View Post
I am not sure if you can tell but the encoder is also on a slot so we can adjust it along with the CIM and make it just kiss the belt so there is almost no side loading. If the belt skips im pretty sure we are just gonna go to chain, we had enough headaches dealing with skipping belts this year
We did consider a bracket like you describe but it was just another part to manufacture and would also put the encoder in a more vulnerable location. If there is some unforeseen mechanical problem with it's current location we may go this route.
I don't think your encoder position will yield good values because it isn't properly engaged with the belt. With the encoder pulley tangent to the belt I don't think the encoder will rotate in perfect relation to the belt. When you have a belt wrapped around a pulley, there is always at least one tooth that is fully engaged with the pulley. This ensures smooth movement. When a pulley is placed tangent to the belt you don't have a tooth constantly engaged with the pulley, because of this there will be some sliding action as the pulley rotates and your encoder values will not reflect the true motion of the belt. This effect is exaggerated when you decrees the size of the pulley.
This is all conjecture, but I highly recommend testing this type of encoder setup or it could come back and bite you.
-Adrian
Unread 03-11-2014, 17:00
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Thanks, I had not thought of this, I will make sure to keep a close eye on it.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
