Thread Tools |
Rating:
Display Modes |
pic: 2 speed ball shifting swerve module
Re: pic: 2 speed ball shifting swerve module
It is based on this design that I posted here previously:
http://www.chiefdelphi.com/media/photos/40805 Last edited by Bryce2471 : 05-11-2014 at 16:20. Reason: typo |
Hard to tell from this angle, but do you have enough space between the CIM and the ground to properly route the CIM's wires?
I'm not sure what the minimum bend radius is. I left 0.3in of ground clearance, but that can easily be changed.
.3 not including wires? Thats not gonna work, even on a "flat" field there are usually 1/4" bumps.
The wires survived... but had visible wear and slight damage. I wouldn't recommend such minimal clearance (especially with the CIM so far from the wheel). |
Yeah, you're probably right. As I said it's pretty easy to adjust, so I'll jack it up a little. probably closer to 5/8".
I've found a few options for gear ratio.
Quoting free speed and inches per CIM rev: Current configuration 11.5fps (1.48ipr) in low, 18.3fps (2.36ipr) in high or 9.15fps (1.18ipr) in low, 14.5fps (1.88ipr) in high or 10.9fps (1.41ipr) in low, 30.5fps (3.93ipr) in high Any of these could be adjusted further with the belt on top. Although, I'd like to avoid that if I can, because it would mean that two types of pulley stock would be required. Let me know which one seems more appealing and why. |
#10
I would go 18.3fps personally, but more spread would be necessary to make it traction limited. 14.5fps is too low for my tastes.
#11
I tend to agree; especially sense those are at free speed and being traction limited is not a major goal of this drive.
#12
Those are free speed? Then you might even be able to gear higher...
#13
How far off the ground is the bottom of the CIM? Any concern for wires dragging or catching on field debris? What is the spread on the gearbox?
What was the weight estimated at? I knew you were shooting for a low number, how'd you end up? |
#14
Do you have a weight / weight difference from the single speed?
(What is this, the week of swerves? 2015 should be fun ) |
#15
6.7lbs including most of the hardware, but not all. Final ratios ar 3.66 and 5.866 to 1. With 2.7" wheel. Smallish spread for auto shifting code. Dimensions 3" wide, 10" tall and 9" long. The single speed version is about an inch shorter, and should weigh 5.9lbs. Last edited by Bryce2471 : 05-11-2014 at 16:28. |
