Go to Post During the year I can't wait for the game hint to be released, but then as soon as it is released and I read it for the first time my head starts to hurt and I regret reading it at all... - Jon Jack [more]
Unread 05-11-2014, 23:26
FRC Team CC FRC Team CC is offline
FRC #6560 (Charging Champions)
Rookie Year: 2012
FRC Team CC is an unknown quantity at this point
Exclamation [FTC]: Broken Fuse/Broken (Tetrix) Battery?!?!?!
Chief Delphi,
About a half an hour ago, our team was going to test out the electronics connections (battery pack, on/off switch, samantha, motor controllers, etc). When we flipped the switch to the "on" position, the lights turned on for two seconds, and then died. We kept turning it on, but none of the components (samantha, controllers, etc) worked.
We have wired the red wires together and the black wires together. Previously, this setup worked.
We are now trying to find the cause of this problem and the solution. We have ruled out the power of the battery because the charger says it has full power.
Could this be a fuse? What would the cause be? How do we fix it?
Regards,
The Charging Champions
Unread 05-11-2014, 23:39
maths222 maths222 is offline
FTC FTA
AKA: Jacob Burroughs
Rookie Year: 2010
maths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to behold
Re: [FTC]: Broken Fuse/Broken (Tetrix) Battery?!?!?!
Sounds like a blown fuse (if the fuse is blown the charger will show fully charged). The fuse is under the black cover on the battery and is a 20a ATM fuse. EX: http://www.walmart.com/ip/Cooper-Bus...Count/20971324
--Jacob
Illinois FTC FTA
Unread 05-11-2014, 23:41
Jeremy Germita's Avatar
Jeremy Germita Jeremy Germita is online now
Co-Advisor/Lead Engineering Mentor
AKA: wood is good. plastic is fantastic.
FRC #5012 (Gryffingear) / (Antelope Valley FIRST Teams)
Team Role: Coach
Rookie Year: 2007
Jeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond repute
If the lights turned on momentarily then shut off, I'd be willing to bet that the main fuse did blow.
There should be an inline fuse holder on the positive lead of the battery. Open that up and take a look at the fuse inside. It's easily replaceable. You can buy packs of 5 for about $3 on Mcmaster-Carr with the part # 7460K517 or at your local hardware/automotive store for under $10.
Did you turn the power on while the robot was enabled(NXT was sending motor commands?) If the robot was not enabled, check your wiring as there may be a short somewhere along the system, causing the fuse to blow.
Here's what I'd do to check the electrical system:
1. Unplug all but the first device in the chain
2. Power on.
3. If power does not die, power off and connect the next device in the system.
4. Repeat 2-3 until your entire system is tested.
If power cuts out after you connect a device, then the problem lies in that device.
One other thing I'd check is your battery connection. The Tamiya battery connectors have given my teams some weird problems if they weren't seated properly.
Drive Coach Team 5012 Gryffingear / Antelope Valley FIRST teams / EWCP - (2013 - Current)
Student / Driver / Programmer / CAD - FRC Team 399: Eagle Robotics / FTC Team 72: GarageBots - (2009 - 2013)
Los Angeles Region FTC FTA/CSA/Head Ref
[FF] FIRST Pick
2014 FTC Los Angeles Regional Compass Award Winner.
2017 - Sacramento Regional / Las Vegas Regional
2016 - Los Angeles Regional Creativity + Winners (1197, 987, 5012) / Las Vegas Regional Team Spirit + SF (5012, 5851, 5049) / Galileo Subdivision
2015 - Inland Empire QF (597, 5012, 4413) / Las Vegas Imagery + Winners (148, 987, 5012) / Newton Subdivision and World Champions (118, 1678, 1671, 5012)
2014 - Inland Empire Rookie All Star + Highest Rookie Seed + SF (2339, 1967, 5012) / Las Vegas Rookie All Star / Galileo Division Imagery
Unread 06-11-2014, 07:55
wgardner's Avatar
wgardner wgardner is online now
Team Role: Coach
Rookie Year: 2012
wgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to behold
Another check is to get a multimeter and check to see if there's voltage across the battery outputs. If not, blown fuse.
Also, you can use the multimeter to check to see if the + and - on your robot are shorted (i.e., check for a short between the two prongs on the connector that the battery plugs into on your robot). Then you can disconnect things until they're not. This is another way to find the short without having to keep plugging in the battery and possibly shorting out more fuses.
Multimeters are pretty cheap at RadioShack and similar places.
CHEER4FTC website and facebook online FTC resources.
Providing support for FTC Teams in the Charlottesville, VA area and beyond.
