Go to Post ...why do programmers have a nesting habit? - Andrew Schreiber [more]
Unread 06-11-2014, 16:15
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
Team Role: Coach
Rookie Year: 2010
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
80/20 as a storage chamber?
I was reading up on some 80/20 information and found this.
Has anyone ever used 80/20 as a pressure tank/manifold in FRC? We've never used 80/20 before due to cost and weight, but I found some uses and this idea intrigues me a little. Maximum pressure is at FRC requirements for past years, I can't think of a reason why it wouldn't be allowed.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 06-11-2014, 16:19
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Re: 80/20 as a storage chamber?
We've talked about this as well. It's worth asking on Q&A, but the 80/20 profiles you need to use it as an air tank are too heavy to be practical. Also, the rule against cutting or modifying pneumatic components comes into play.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 06-11-2014, 16:35
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
I think it would give certain robot inspectors a conniption. . You would have to convince them that the assembly is a COTs device. (2014 R75). Strongly suspect there will be a similar 2015 rule.
80/20 gives a large discount to First teams. Be sure to ask for it when talking to your distributor.
If you don't know what you should hook up then you should read a data sheet
Unread 06-11-2014, 16:55
protoserge's Avatar
protoserge protoserge is offline
CAD, machining, circuits, fun!
AKA: Some call me... Tim?
FRC #0365 (MOE) & former 836 Mentor)
protoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond repute
I can think of reasoning for not allowing it as a load-bearing chassis or manipulator component, but I've seen plenty of poorly-located pneumatic reservoirs before.
I could see this being a recipe for disaster in that poor metal shavings management could yield a lot of internal damage to downstream components if proper care is not taken when installing.
I still don't know if it offers advantages over using the tried and true Pneuaire tanks, though.
Unread 06-11-2014, 19:55
Billfred's Avatar
Billfred Billfred is offline
This was over a decade ago, but I recall reading about one team that used frame members as vacuum accumulators in 2004. Back then pneumatics rules were infinitely more restrictive than today, but vacuum was more or less unregulated. So they carefully sealed up a couple frame members (this was pre-kitbot, so beefier drives were common--heck, the "kit frame" was 2"x4" box aluminum), tapped the fittings, and went to town using that pressure (or lack thereof) instead.
No relevance to here--I think you're more or less hosed--but I dig the historical parallel.
Unread 07-11-2014, 11:25
Jake177's Avatar
Jake177 Jake177 is offline
AKA: JT, Jake Troiano
FRC #0177 (Bobcat Robotics)
Jake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to behold
That was us (unless someone else was crazy enough to try it too).
http://www.chiefdelphi.com/forums/sh...3&postcount=17
Once a Bobcat, always a Bobcat
2001-2004: Student
(I'm told the team had a couple good years in between here)
2012 - Present: Mentor
Unread 07-11-2014, 11:30
Andrew Schreiber Andrew Schreiber is offline
Data Nerd
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
On the topic of other silly accumulators: I believe it was T3 that used large amounts of pneumatic tubing (coiled) as an additional accumulator.
And I mean RIDICULOUSLY large amounts...
Unread 07-11-2014, 14:18
cgmv123's Avatar
AKA: Max Vrany
Rookie Year: 2011
I heard this was because there was a limit on tanks that year, but no limit on tubing.
Unread 07-11-2014, 14:33
Data Nerd
FRC #0079
Rookie Year: 2000
Correct.
Unread 07-11-2014, 17:00
protoserge's Avatar
Never underestimate the creative genius of FIRST participants
Unread 07-11-2014, 21:26
philso philso is offline
Mentor
FRC #2587
Rookie Year: 2011
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
Our ingenious friends at Spectrum (3847) had a clever way of doing this that was very elegant and neat.
Unread 06-11-2014, 16:33
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Assuming the specific model # you buy has a data sheet that lists gas pressure rating, there are two concerns I would have.
FIRST, modification. Did you cut the 80/20 to length?. If so, it's been modified and per the 2014 rules not a legal pneumatic component. If, on the other hand, you can purchase the exact length you need, that may not come into play. I would also look very carefully at how stuff may have been mounted to the 80/20, that could be another source of modification making it illegal as a pneumatic component.
Second, Safety. Like with all pneumatic storage tanks, I'm going to look at the likelihood of it getting hit, bent, or broken. Most tanks can be placed in a relatively protected area... Using 80/20 as both storage and your robot frame would raise a lot of concerns about the damage that could occur when you get hit on the field. From the standpoint of keeping a team running the whole weekend, having a single hard hit to the frame crack or dislodge something and cause you to lose air pressure with what could be a very lengthy fix is highly concerning. And while aluminum doesn't have the same failure mode as some of the plastic tanks we've seen explode, I would be concerned about explosive decompression in an area that is likely very near motors, electronics, and wiring that could all easily be shorted or damaged in such a situation.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
