Go to Post This game is all about dealing with the unexpected and making changes on the fly. - Greg Hainsworth [more]
Go Back   Chief Delphi > Technical > CAD
Thread Tools Rating: Thread Rating: 2 votes, 2.00 average. Display Modes
Unread 07-11-2014, 18:46
75vs1885's Avatar
75vs1885 75vs1885 is offline
AKA: Stephen
FRC #1885 (Ilite)
Team Role: Mechanical
Rookie Year: 2012
75vs1885 will become famous soon enough
how to change orientation of text in Inventor?
Hey,
I'm designing a driverstation with Inventor 2014 and I'm trying to add text (ilite 1885 ilite) to a part, I can add text bu when I do it is going the wrong way. I tried looking it up online but I always get answers about dimension text. When I open the "edit Text" box, I cannot edit the rotation.
I have no clue what to do, does anybody know?!
Thanks a lot
Unread 13-01-2015, 18:21
SteamlyPunk's Avatar
SteamlyPunk SteamlyPunk is offline
AKA: Guy
FRC #1577 (Steampunk)
Team Role: CAD
Rookie Year: 2014
SteamlyPunk is an unknown quantity at this point
Re: how to change orientation of text in Inventor?
Hi stephen,
If I understood you correctly, your text is oriented in the wrong direction(ie. top to bottom, upside down, etc).
That is mainly caused because you aren't looking at your part the correct way. You can know that by looking at the 'Viewcube' at the top right side of your screen. If the text there isn't oriented correctly, then you simply aren't looking at the object the correct way.
In order to rotate the text, while in Sketch Mode you can simply use the Rotate function in the Modify tab at the top of your work area, when you click it a window will open where you'll choose what geometry you'd like to rotate (your text) and around what point.
Hope it helped!
-Guy
Unread 19-01-2015, 22:39
75vs1885's Avatar
AKA: Stephen
FRC #1885 (Ilite)
Rookie Year: 2012
This helped a lot!
Thanks!!
Alumni from 75 and 1885
