Go to Post You never really graduate out of FIRST.... - Gnomegirl [more]
Unread 12-11-2014, 00:55
Andrew Lawrence
Posts: n/a
Examples of when it is not advantageous to be lightweight
Aside from the obvious loss of friction due to a decreased normal force affecting pushing ability, I cannot think of any specific examples in FRC history when it has been disadvantageous to be as light as possible. Is there anything I am missing, and if so, could you cite a specific match that shows this weakness due to weight? Also, is there a limit with weight where, like adding motors, you reach a point where it becomes less and less advantageous to become lighter?
I appreciate all input.
Unread 12-11-2014, 01:04
madhav's Avatar
madhav madhav is offline
AKA: Madhav Gharmalkar
FRC #4276 (Viking Robotics)
Team Role: Communications
Rookie Year: 2012
madhav will become famous soon enough
Re: Examples of when it is not advantageous to be lightweight
2012 Bridge Balancing issues?
I'm tired, I'll get back to you tomorrow
Unread 12-11-2014, 01:09
Travis Schuh Travis Schuh is offline
FRC #0971 (Spartan Robotics)
Rookie Year: 1999
Travis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant future
I think your implicit assumption is that being lighter gives you a more maneuverable robot by decreasing acceleration time.
If your goal is to make your robot more maneuverable, then I could see taking weight out of your robot at the cost of raising your CG above an acceptable height resulting in a net decrease in maneuverability. If there is no option to lower CG through re-arranging components, then it may make sense to ballast the robot. It also helps if the CG is closer to the center of the robot for best handling. I think for these reasons contributed to 254 ballasting their robot this year.
There are plenty of matches where teams either outright tipped or had to drive cautiously because they were tippy (you asked for specific matches, I would say watch some of 973's 2013 matches). I bet many of these teams would have added ballast if they had weight.
Unread 12-11-2014, 01:32
Andrew Lawrence
Posts: n/a
Part is maneuverability, though the main reason is I just can't think of a reason to be heavy. 1323's resources make machining for weight easy enough, and I think it would be a useful engineering goal for the kids to shoot for in season to design for a lightweight yet strong robot if the game allows for a lightweight robot as a viable strategy. Also it would be a good way to allocate weight lower into the drivetrain to make a lower CG (which has been a clear problem for us this year).
One of the first things many mentors I have learned from tend to tell me is how to lighten a robot and that "lighter is better" (not always true, but it's a point that has been stressed enough to me in my education that I started this thread because of it, though further learning could prove differently) and while I understand the potential advantages of a lower weight, I cannot think of many reasons for increased weight. More mass in a robot just makes it harder to move, and I don't see any advantages to that, and want to learn what I may be missing.
Unread 12-11-2014, 01:54
Kevin Sheridan's Avatar
Kevin Sheridan Kevin Sheridan is offline
FRC #0254 (The Cheesy Poofs)
Kevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond repute
When I was on 766 we made our robots as heavy as possible in 2006 and 2007 so we would not tip going up/down the ramps. I saw a lot of robots tip in 2006 especially because they were too top heavy. A common tactic that year was to shove top heavy robots up your own ramp on defense so they would risk tipping trying to come down the ramp during teleop.
Unread 12-11-2014, 02:24
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
I think this is always true of subsystems, including the drive, until you start to sacrifice structural integrity, but not true for the robot as a whole. When I say "lighter is better" it is usually because if it's not stressed you get to week 5 with a 150lb robot and a major sub system has to be removed because there is no time to redesign all of them to be lighter. On MOE we always have 120.00lb robots because we usually shoot for maximum functionality (do all the things!) and this usually requires more weight than a robot specialized to do a specific task. We embrace this so much that if we get to week 4 or 5 and realize we have 4lb to spare we try to think of a way to use that 4lb to make our job easier, more reliable, or faster.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 12-11-2014, 13:30
Michael Hill's Avatar
Michael Hill Michael Hill is offline
FRC #3138 (Innovators Robotics)
Michael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond repute
Definitely agree with the structural integrity comment. I would much rather use a thinner material before I use lightening holes. Remember the saying "only as strong as the weakest link"? That applies to structures. Your robot is only as strong as the smallest cross-sectional area. When you have lightening holes, especially ones that are close together, you create a distinct point of failure. If you just design it with thinner material from the start, you can likely avoid lightening holes altogether and maintain a larger cross-section than you would have with a lightened structure.
Unread 14-11-2014, 06:39
MichaelBick MichaelBick is online now
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
In compression, strength is correlated with geometry not cross-sectional area.
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
Unread 14-11-2014, 13:59
I'm not sure I follow the logic here. I'm saying use the same shape, just a thinner material. Also, I would also say that compressive strength IS related to cross sectional area. It uses the same equations as in tension. Also, in terms of buckling, the point at which something will buckle is related to the cross-sectional area.
Unread 14-11-2014, 14:36
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
I would distiguish between designing the robot to be as light as possible and actually being as light as possible.
Designing to be light* is always a good idea, for the simple reason of it being significantly easier to add weight than remove it.
Whether actually being light is a benefit depends on the game and your team's strategy in that game.
*To paraphrase "As light as possible but no lighter."
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 14-11-2014, 14:39
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Originally Posted by EricH View Post
[snip]
That said... maybe one of the REAL old-timers on here can give us a rundown of the classic award, "Flyweight in the Finals"!
Ugh, I'm not a REAL old-timer... but I do remember "Featherweight in the Finals" that our iconic robot, Grace Hopper, won in 2000. If memory serves (and it might not) Featherweight in the Finals was awarded to the lightest robot in either the final bracket or all of the eliminations.
Sort of... it's related to the cross-section inertia of the beam, strictly speaking, not the area. Compressive stress IS related to the XC area, but generally speaking this is very rarely the limiting factor.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Last edited by JamesCH95 : 14-11-2014 at 15:06. Reason: Edited because I TOTALLY misread OP.
Unread 17-11-2014, 19:45
yash101 yash101 is offline
Curiosity | I have too much of it!
AKA: null
Rookie Year: 2012
yash101 is an unknown quantity at this point
i want to do pathfinding this year, and I've figured out that it would be extremely important for the robot to by capable of changing directions quickly and accelerating quickly, so that the robot will be able to follow the path and change paths with almost no smoothing and any overhead of acceleration time.
I think that this means that the robot will need:
-Tons of power in the drivetrain
-Lightweight
-COG: Center, at the bottom!
Unread 18-11-2014, 08:08
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
-Lightweight
What you have here is a great recipe for spinning wheels. Would that make accurate path-finding more or less difficult to implement successfully?
Bonus question: how does wheel tread selection play into your goals?
Unread 12-11-2014, 03:45
Rookie Year: 2010
Drive size has a lot more to do with this than your drive weight.
  #15   Spotlight this post!
Unread 12-11-2014, 06:24
scaryone's Avatar
scaryone scaryone is offline
FRC #0058 (The Riot Crew)
Team Role: Coach
Rookie Year: 2007
scaryone will become famous soon enough
We added weight to the base of this year's bot to avoid tipping over. (top-heavy)
