Thread Tools |
Rating:
Display Modes |
pic: REV Robotics building system
Re: pic: REV Robotics building system
Is the linear motion system supported by ball bearings or bushings?
![]() Last edited by Greg Needel : 11-14-2014 at 07:35 PM. |
Do you have any idea when "very soon" is?
This looks cool. |
Awesome! (image seems to be broken BTW)
This looks suspiciously similar to a certain Industrial Erector Set.
Greg, any way to get strengths/specs? I am really looking forward to the products REV Robotics are releasing. |
I love the fact that you can use standard hardware with this. I might be missing something obvious, but what are the grooves in the corners meant for.
Looks like you could tap them.
#10
That makes sense. I was just confuse by the openings. I guess it just makes it easier to manufacture.
#12
1) standard hardware decreases the cost of every attachment point from $.40 per nut (.20 if you are lucky) down to .02 by using standard hardware. This gives you the build experience that is so awesome at a much more cost effective price for schools and teams. 2) Linear motion is normally hard or expensive. Over the past 13 seasons I have been involved in FIRST there have been many amazing products which have changed the game (things like the shifting transmission, systems of gearboxes, sprockets, and wheels that just work together). The one thing that has remained hard for teams is linear motion. There are low cost options like drawer slides and more pricey solutions like ground rods and linear bearings but up to this point nothing that was designed with building a robotics elevator in mind. The V groove bearings and integrated features in the 1 inch profile allow for super easy integration anywhere in your mechanism. Quote:
As for the corners there are a few reasons (some more obvious than others). When you design a part to be aluminum extruded it is in your best interest to keep a constant wall thickness through your part, this helps with the flow of the aluminum (similar things come into play when designing plastic parts also). Secondly the amount of closed profiles in your extrusion makes the dies more expensive and harder to get consistent results. Specifically speaking to the 15 mm profile it would have been almost impossible to do a closed hole in the corner. As mentioned above all 5 of the holes can be tapped with allows for some interesting applications, one of which is mounting a hub to the end and driving it with a motor to turn our extrusions into a shaft that could be used for a pickup. Along that same lines the slot in the corner is specifically sized to accept a 1/6" piece of flat stock (lexan or other), I am sure you can probably think of a few times this would be useful ![]() |
#13
I do think that this is a really cool addition to teams' resources though. With the sliding nuts on each side it could especially have FRC applications in rapid prototyping. Cheers, Bryan |
#14
I will be ordering some of your extrusion and bearings for our team.
I have made a drilling tool for working with robotextrusions, and it has the 5 hole pattern to fit the end of your 1 inch shape incorporated so it will be easy for teams to use it. You can see it at robotextrusions.com |
