Go to Post Yes, in human nature we like to get rewarded/recognized for things we do; however, you should not have to rely on this to be "successful". Remember the purpose of FIRST - To change our culture. - tim-tim [more]
Unread 20-11-2014, 13:10
yarden.saa's Avatar
yarden.saa yarden.saa is offline
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
yarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond repute
Belt Drive Design Problem
Hi CD,
For the first time I am trying to design a drivetrain with belts. I would like to keep everything in the minimum size.
**I will attach a photo of the drivetrain I want to convet to belts.
We are using a direct drive with hex shaft. the problem is that Vex doesn't offer pulleys it the same diameter as the hex pulleys. adding a hex hub over the pulleys will make the thickness of the wheel+pulley+hexhub+bolts+nuts too thick. I looked at andymark solution in their AM14U, they made holes in their pulley so the hub will fit in the pulley. I am looking for a solution that will work with vex wheels because andymark pulleys doesn't have the versa key pattern. Andymark variety of pulleys and belts is pretty small so I can allow my self using it.
ID:	17491  Click image for larger version
2016 - Curie Sub-division Winners, Regional Winners
2015 - Carson Sub-division Winners, Regional Winners
2012 - 3339 Captain and Dean's List Finalist
