Thread Tools |
Rating:
Display Modes |
One tool/machine to level up a moderate shop
This question has been asked many times before, so I will pose it in a slightly different way.
Say your team has a modest shop facility. You have most mid-range tools such as cordless drills, manual hand tools, calipers, jig saws, chop saws, drill press, band saw, grinders, and belt sanders. Basically, you can generally do small scale fabrication without a lot of precision. What is THE ONE tool/machine you would get to level up your shop? I know the usual top two machines that get suggested but I want to ask, if you can only get one, what one should it be? Don't worry too much about price, anywhere from a couple hundred to a little over a thousand is reasonable. Last edited by Monochron : 21-11-2014 at 15:17. |
Re: One tool/machine to level up a moderate shop
Actually the next step I would take is some precision measuring tools. Calipers, depth indicators, etc.
A lathe would be the first machine tool I would recommend. There are many uses and it does things that none of the hand tools and general tools can do. It is the first step towards precision. You can make many things from HDPE to serve as a low speed bearing. Shafts, spacers, etc etc. It is not necessary to have a digital readout for the lathe (although it is nice if you can afford it) It is often said that with a lathe you can make a mill. I wouldn't try it though. Just remember that when you take the step toward machine tools you will need at least an equal budget for the "tools" that you will put in them as you do for the machine itself. Good luck |
A manual milling machine probably used from someone that took care of it.
I often see them under $1,500 if you can find a way to move it. While you search for that you might be surprised and end up with a lathe and mill for that price. Watch Craigslist - there's a few Bridgeports right now in your price range in the Philadelphia and NJ areas and I searched the NC area and found several hits for around $1,000 for the term milling machine. I've had a few cases where a skilled craftsman has this stuff at their home shop and is just trying to be rid of it for one reason or another. I've brokered whole Bridgeports with tools for at little as $400 in the past. I have a ShopTask mill/drill/lathe in my garage that I got for $1,000 with 2 large tool boxes of tools and the CNC mounts. Just make sure you understand what power is actually available in your shop (single phase, 3 phase, etc...) Last edited by techhelpbb : 22-11-2014 at 00:41. |
We invested in a horizontal band saw this off-season. So far we've found it's been much easier to get accurate cuts and the newer students seem to be a little more comfortable using it compared to the vertical or miter saw.
One thing I didn't see on your 'standard' list is an arbor press. Get an arbor press if you don't have one, makes pressing bearings so much easier. |
I have to put my vote for a mill. If the part can be held in a collet it can be turned in a mill with out much trouble. Trying to mill in a lathe take special attachments.
For piece of mind, it's hard to beat a Coldsaw as an upgrade from a chop saw. For $1,000 you can be assured that students would have to work REALLY hard to cut off a finger when cutting aluminum. The saw only turns at about 70 rpm and the material is firmly clamped.
I have one of these, pretty handy:
http://www.evolutionpowertools.com/us/build/rage3.php It's got a special blade and the drive is geared. Not quite cold saw RPM though. It is around $300. |
I would recommend the Rage 3 saw that someone else mentioned. It's going to do a faster job with nearly equal cut quality and save you a bunch of money. |
For your specific needs, I really can only be generic: I would need to see what you build now to identify from which capabilities you may best benefit. Maybe you can do this yourself, or enlist someone unfamiliar with your team (but familiar with machining or constructing things) to take a close look. That being said: Well, the top 2 are there because they are the most useful. Data point: At home I have a lathe and mill. I make a LOT more things with the lathe. I find that I can almost always make things that might have been milled...without the mill. Data point: A lathe for $1k is no problem. A mill for $1k is iffy. Both include tooling. |
#11
![]() So, a bit of a follow up question then. A couple of people have said that with additional tooling you can do many "mill tasks" with a lathe. Is it feasible to purchase a lathe now, and then over time step up the lathe to do a couple milling tasks? It wouldn't give us the machining power of a full mill, but we could make do with a little pain and extra effort? And it would satisfy the "one machine" part of the question. ![]() I ask because, like I said above, I envision a gradual increase in our tool quality and abilities, not a big jump one year. Getting a cheaper tool that can do some of the things that a more expensive tool can do, may tide us over until we are able to step things up further. |
#12
If nobody on your team knows how to use a mill or lathe, check your local community college for machining classes. They're fun and often times you can use the tools there anyway. |
#13
Do check the community college's policies, though, just to make sure. |
#14
Knee Mill - Bridgeport.
Call around to your local manufacturers. Ask if they can part with a mill in exchange for a sponsor-level. We got a knee mill donated by Darter Plastics inc - a local manufacturer. The company may find a way to rid themselves of an old piece of machinery that will become invaluable to your shop. |
#15
For FRC use, definitely lathe>mill if for no other reason than how many COTS parts now are made for hex shaft.
