Go to Post I'm going to get kicked out of the mentor club for this one... - Not2B [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 22-11-2014, 14:01
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
Re: One tool/machine to level up a moderate shop
Originally Posted by Sam_Mills View Post
For FRC use, definitely lathe>mill if for no other reason than how many COTS parts now are made for hex shaft.
There are ways of getting around these issues. You can buy spacers and shaft collars.
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
Unread 22-11-2014, 14:59
Sam_Mills's Avatar
Sam_Mills Sam_Mills is offline
FRC #4965 (FIRE)
Rookie Year: 2010
Sam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond repute
Fair point, especially with FRC time constraints when it may not be practical to spend time making tons of snap ring grooves. Although it is at the cost of a little weight.
Lathes have other uses however. Centering holes in round stock to quickly make standoffs is a big one. You can also tap holes with a lathe, and I have even known some teams to use it to broach.
IMO it is also much quicker to learn how to correctly use a lathe than it is a mill, an important thing to consider when you have high school students using machines.
2013 MORT 11: Captain/Driver 60 - 19 - 1
2014-current FIRE 4965: Engineering Mentor
ewcp 2013-current
If you argue with math, you are going to lose.
Unread 22-11-2014, 18:40
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
A decent quality, used lathe will unlock much more potential than any other tool at the same price range.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 23-11-2014, 07:57
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by Monochron View Post
Slow and steady improvements to quality facilities will be part of our path to success
So, a bit of a follow up question then. A couple of people have said that with additional tooling you can do many "mill tasks" with a lathe. Is it feasible to purchase a lathe now, and then over time step up the lathe to do a couple milling tasks? It wouldn't give us the machining power of a full mill, but we could make do with a little pain and extra effort?
Yes, you can do light and limited milling with a lathe, using an attachment like the one shown on this page. For newer "non-collectable" lathes you can get one for under $150, but for old Atlas lathes I've seen these for $400+. Of course, you're not making sideplates with this, but most milling tasks are possible, albeit a little more time-consuming (you have to go slow).
An alternative is an X-Y milling vise for your drill press. You can do light milling with somewhat more flexibility than the lathe setup. Avoid the very cheap ones, they are terribly inaccurate. These are great for drilling accurate hole patterns as well (and often that's the only use they see).
Fair warning: Even if your drill press is a huge industrial beefy monster, this WILL hurt the spindle bearings a little each time you use it, but perhaps this trade-off is acceptable. New bearings are not costly, and the repair is good for the kids to learn. But a drill press is not designed for side loading on the chuck, just know that.
Give yourself some time to find a good machine, maybe a whole year. Find a parent or local business willing to show you the basics (or the trade school option mentioned above). Buy the book "How to run a Lathe" - way old school (100 years ago!) but a treasure trove of excellent data and instruction. Ask here, there are many who would be tickled pink to help.
Unread 23-11-2014, 10:24
Jacob Plicque Jacob Plicque is offline
FRC #0086 (Team Resistance)
Jacob Plicque is an unknown quantity at this point
I suggest getting a surplus mill or lathe from a regional machine shop or manufacturer or workshop enthusist. We have three machines (two free) with a complete set of tools with a total investment of ~$1K plus a trailer rental for a 300 mile one way travel. It can be done on small budget like yours. Our equipment ranges in age from 20 to 40+ years but they are in full working order. Each unit has some quirks/idiosyncrasies which can be overcome by testing and measuring the results.
Unread 23-11-2014, 11:01
Oblarg Oblarg is online now
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
Do you find that putting one of these on a standard drill press holds tight enough tolerances for tube/gusset plate constructions? We've been doing those purely by match-drilling, but being able to drill them independently would be very nice.
Also, if you do have your drill press set up with one of these, do you just use an edge finder in the drill press the same way you would on a mill?
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
Unread 23-11-2014, 15:48
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Good advice. However, I disagree about the X-Y table for the drill press. Drill presses are not designed AT ALL for milling. If/when the spindle bearings fail, then the whole thing becomes a massive safety hazard. This is not a substitute for a mill and should not be used as one or anything other than plastic.
Unread 23-11-2014, 16:07
Team118Joseph's Avatar
Team118Joseph Team118Joseph is offline
The guy that did the lighting
AKA: Joseph Foster
FRC #0118 (Robonauts)
Rookie Year: 2013
Team118Joseph will become famous soon enoughTeam118Joseph will become famous soon enough
I recommend pneumatic rivet pullers and other pneumatic tools. They are usually more compact and can produce higher speeds.
Unread 23-11-2014, 17:23
Seth Mallory Seth Mallory is offline
FRC #0192 (GRT)
Seth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond repute
Are you planning this for this season? If so buy to mach your skills. If your team has lathe skill but not milling than buy a lathe. The same goes for mill or 3d printer or any other tools. It is not worth trying to learn how to use a tool during build. A mentor with sheet metal skills can do more for a team teaching the students with a shear and a brake then mill taking up need valuable time during build.
KF6UZX
Unread 23-11-2014, 17:18
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
I would say that if your primary interest in a mill is the ability to precisely locate features and do hole patterns, an X/Y table and drill press is a great choice. However, as soon as jobs that require endmills get introduced, time to step it up to a real mill.
I will second the many suggestions in this thread to look to the used market. Be patient, and you'll find some great deals. My team got a FANTASTIC deal on a great quality off-brand Series 1 mill clone, with DRO, work holding, and X power feed included, for $700. We've also gotten a 12" lathe at a used tool shop for $600, and had a smaller lathe donated.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 23-11-2014, 20:14
Travis Schuh Travis Schuh is offline
FRC #0971 (Spartan Robotics)
Rookie Year: 1999
Travis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant future
I agree that you could use an XY vice on a drill press for preciser hole centers to centers, but I would highly recommend against doing milling. Most drill chucks are held in with just the friction of a morse taper. Milling will add side vibration loads that will loosen this hold, and ultimately have the chuck fall out on you.
Unread 23-11-2014, 20:46
scottandme's Avatar
scottandme scottandme is offline
AKA: Scott Meredith
FRC #5895 (Peddie School Robotics)
Team Role: Teacher
scottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond repute
Not to pile on top of the previous comments, but also note that drill chucks are unable to safely sustain radial loads, even when used in a proper milling machine.
Some tiny benchtop milling machines do have morse taper spindles, but they are designed for (small) radial loads, and include a drawbar like a regular milling machine would have.
On topic - used is the way to go with your budget, but make sure you have someone familiar enough with a mill/lathe to make sure it's in decent operating condition. A beat to death bridgeport with a ton of backlash wouldn't be ideal.
Team 2590 Mentor [2009-2014]
Team 5895 Mentor [2016-Present]
Unread 23-11-2014, 22:55
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
Good call on the drill chucks.
On backlash: it's not a huge problem if you have a DRO and a reasonably heavy mill. I've been meaning to ask our maching mentor about tightening up the backlash on our Bridgeport, as it currently has around 0.060" of backlash. It has never been a problem for us as we only take light to medium cuts in aluminum, so as long as you're careful and don't heavy climb mill it should be fine.
I agree that somebody knowledgeable about mills/ lathes whould go with you. Take along a checklist or something at the very least. Make sure that there's no rust in the spindle or on the ways, that it's not pitted to oblivion and flat, etc.
Unread 24-11-2014, 11:45
James3245 James3245 is offline
Mentor
FRC #3245 (Ravens)
Rookie Year: 2010
James3245 is on a distinguished road
Count me as a mentor who has been pleased with a cold saw.
We've been cutting (yes it is slow) aluminum for a couple of seasons without injury. We did break a blade once when the stock was not long enough to clamp properly. Because of the low rpm the incident was alarming and instructive but not particularly dangerous.
I will accept slow cuts, and higher upfront cost, to avoid the hazard (see other CD posts for scary stories of flying metal) of having anyone, especially students, cut metal with a high-speed chop saw. Not to mention the screeching.
A pneumatic rivet gun set up is relatively cheap and as posted earlier a great next tool. And quite safe.
  #15   Spotlight this post!
Unread 24-11-2014, 14:42
AKA: Eli Barnett
Can anyone who's used an x-y milling vise on a drill press answer my question about edge-finding?
