Go to Post When you do something great, it just feels good. - tiffany34990 [more]
Unread 22-11-2014, 06:04
matan129 matan129 is offline
FRC #4757 (Talos)
Rookie Year: 2015
matan129 is an unknown quantity at this point
Power Distrobution Panel + Jetson TK1
Hey,
My team has acquired a Jetson TK1 for this year. I was wondering if there's any convenient way to power it from the Power Dist. Panel?
Thanks,
Matan
Unread 22-11-2014, 11:43
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Power Distrobution Panel + Jetson TK1
The TK1 runs on 12 volts (and can work down to 9.6 volts). A straightforward connection from a normal pair of Wago connections on the PDP through an appropriately-sized barrel connector seems to me like it would be fine.
Unread 22-11-2014, 16:01
yash101 yash101 is offline
Curiosity | I have too much of it!
AKA: null
Rookie Year: 2012
yash101 is an unknown quantity at this point
Wouldn't it be a really good idea to add a buck-boost convertor before it? This way, those pesky voltage spikes and drops won't do anything to it. The voltage in batteries can easily dip below 9.6v during competitive maneuvers! It's just about timing when all the motors turn on on the robot at the same time .
Unread 22-11-2014, 16:34
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
If it draws less than 2 amps 1.5 amps, you can run it through the Voltage Regulator Module.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 22-11-2014, 17:03
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Originally Posted by cgmv123 View Post
If it draws less than 2 amps, you can run it through the Voltage Regulator Module.
Less than or equal to 1.5a
Let's not destroy any VRM's here.
Unread 22-11-2014, 17:24
AKA: null
Rookie Year: 2012
If you are talking about the convertor used by the bridge, note that it runs at 5v. The voltage required by the Jetson (min) is 9.6v!
Unread 22-11-2014, 17:39
cgmv123's Avatar
AKA: Max Vrany
Rookie Year: 2011
Noted.
There's a 5V rail and a 12V rail.
