Go to Post FIRST is an amazing combination of principles that, when applied to the world, has had a monstrous effect on the way High School students learn, think, and relate to others. - Amanda M [more]
  #106   Spotlight this post!
Unread 28-12-2014, 22:43
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
Re: One speed vs Two speed gearboxes
Originally Posted by Ekcrbe View Post
I know that for the last few years, we've had high/low splits of right around 3:1 and free speeds of ~5/15 FPS, and I can't imagine wanting them to be any closer together than that. Even with only 4 CIMs, starting in high gear is fine and low can be almost exclusively reserved for pushing and fine control. A simple software adjustment like squaring the drive joystick values makes control in high gear noticeably more manageable, and if we were to change anything, I would say we would try to push it faster before deciding to slow it down.
The information in my post was intended to be used as a guide, rather than a matter of fact. When all things are considered (specifically wheel type, robot weight, rotating mass weight, strategic intent) a drivetrains specifics should naturally fall into place.
That being said, history (2013 newton) tells me that 68 is no stranger to getting across the field quickly, so if the application is similar, there's no doubt in my mind that your data is spot on.
Going back to my original post, much of drive design beyond the basic 90-95% or so (essentially optimization of the system) is very application specific, and is best catered towards a robot and it's driver. So no matter what, much of this data should be taken as a starting point, and adjusted from there. Enough adjustment, and you might just attain perfection... If you've got the time.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
  #107   Spotlight this post!
Unread 28-12-2014, 23:01
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
When can I watch Einstein again?
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Rookie Year: 2012
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
Very fair. It's probably a good rule of thumb so you can push the envelope without getting burned.
That robot was really good at a couple things, one of them being getting across the field (the other was standing back up after we tipped it over ), and it was a lot of fun to drive.
That also is some very good advice. The best I can give is this: One speed or two speed, if you've found a drive system that will work for you and meet your objectives on the field, that's usually pretty independent of game specifics. Stick to that system and get your last 5-10% out of it. That will serve you far more than starting over the next season with a "better" system. Once you've nailed that one down or decide it's not going to meet your goals any longer, look at something else (hopefully in the offseason) and consider it.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
