| Thread Tools |
Rating:
Display Modes |
#16
Re: 2073 is looking into WCD, feedback requested
You may want to locate the CRio and Digital Sidecar together on one side, say where you currently have pneumatic valves and compressor. Locate the compressor where the air tanks are now. The air tanks are pretty light so they can be put in the middle or up on the upper structure. You may want to install the pneumatic gauge higher up and turned around (as Frank suggested) so it can be seen over the bumpers. Moving the radio to the other end will put it closer to the CRio that it connects to and away from potential noise sources (motor controllers). If possible, mount the radio on a light piece of plastic in a space in the upper structure so that it is physically protected and not surround it with metal (for better reception). Last edited by philso : 25-11-2014 at 13:43. |
#17
Thank you for the feedback. Yes the little tabs are for the bumpers. Throughout the 2014 season we used a similar fashion for mounting the bumpers. How do you suggest we support them? I felt like keeping them away from the edge would allow them from being bent by having all the force of impact be disbursed throught the 2x1. Any suggestions would appreciated.
#18
If you are concerned about running chains inside the frame perimeter you can easily put the sprockets on the back of the wheels and run the chain system that way. It will reduce the interior available space but will eliminate the need for chain covers. The chain covers will reduce the interior space available so in reality it about the same amount of space. If you like I can send you our CAD from last year.
Here is one of our CAD models with chain runs behind the wheels. Pardon the overly large sprockets.. We ended up moving the chain to the interior for that year. http://www.chiefdelphi.com/media/img...9ae90ccd_l.jpg Last year we used the WCP 3CIM DS transmission with chain runs inside the frame perimeter. We installed chain covers, like on a bicycle. The chain covers worked just fine but this year we are going to run the sprocket & chains in the frame.. http://www.chiefdelphi.com/media/img...e70e30e9_l.jpg Keep it up!! Aloha Mr H. |
#23
Do you have the center wheel dropped lower? If so, how much lower? I think I have seen some teams that did not drop their center wheel, how much of a difference is this? Is it beneficial or not? For those that did not drop the center wheel, would you recommend it?
#25
Many of the suggestions here have been incorporated into an updated version. I will see if I can get the improved version up soon. |
#26
1/8" drop is the norm for the center wheels. If you keep the weight centered well enough, spinning around is very easy! As mentioned, even when weight is not centered, on a drop center drive the robot will rock to one end and essentially be 4wd with a short wheelbase, which will turn much easier with less scrubbing than 6wd non drop.. Yeah robot doughnuts! Aloha! |
#27
I'd recommend using colsons and then shaving down the center wheel till happy with your drop. We started out with 3/32 and ended up with 1/16 or none.
#28
By intentionally shaving down the center wheel, which usually wears down fastest anyway, aren't you introducing a different effective FPS from the center wheels than the front and rear wheels? I know this is done on purpose with some 4x4 vehicles to increase traction on surfaces that will allow slippage, like sand or gravel. Are you suggesting to do this as a way to determine optimum drop, or something else. |
#29
We started with 1/8" and kept it. By championship it was worn close to 1/16th and ran like a champ.. Though might of been that WCP 3CIM DS transmission... With the deformation of the carpet and the Colson wheels, it was ready to go at 1/8" ! I will get the CADs up over the long weekend.. like the end of it because the weather is great! Aloha |
#30
Thanks everyone who gave suggestions and comments. This is almost becoming a "Design by Community" project.
Here are two new renders. Most of the suggestions have been incorporated now. In the oblique projection, we noticed the tension cam is on the wrong side of the block. Ooops! It is corrected in the overhead render. ![]() ![]() Full Res images here and here. |
