| Thread Tools |
Rating:
Display Modes |
#31
Re: 2073 is looking into WCD, feedback requested
The people running the wiring and the pneumatic tubing will be much happier with this version.
You may want to move the solenoids and the Spike a bit so you can move the Digital Sidecar away from the CRio to allow space for PWM cables. You may want to mount your pressure gauge in a small, protected space in your upper structure that makes it visible. You may also want to add a voltmeter next to the pressure gauge. We found it handy for knowing when to stop the practice and change batteries. http://www.amazon.com/s/?ie=UTF8&key...l_4s6cbqg7iv_e |
#32
Many of the items included in this render will not be located where they are due to the new RoboRio controller and speed controllers. No DSC's with the new controller, so that will give a bit of extra room. Additionally, the new game will dictate changes that can't be anticipate at this point in time. |
#33
Who on the team would be a good candidate for this project? |
#35
All of this said, there are compelling reasons to use chain over belt, particularly if you are running the power transmission external to the tube. Chain drive external saves weight in using a smaller extrusion profile, and I guess it saves a little space too. In the case of using belts outside of the tube, a belt drive failure would require removal and disassembly of the gearbox, and that's no fun. It's really up to preference, and whether or not you want to tension after the fact or not. If you like tensioners and bearing blocks, chain is a lot easier. If you can machine "exact centers", where your wheels are fixed the exact distance apart that a belt calls for, and you don't mind a "fatter" drive tube, belt drives are nice. So maybe they weren't wrong... Just thought I'd add some data and explain the logic behind internal belt drives a little bit more. |
#37
So if you make sure to put the right size belts in, they can be a great system. But I would not use 9mm belts with 24t pulleys. You will most likely have a bad time if you do. |
#38
We're also looking at WCD this year and doing something similar to your setup. We are mounting the gearbox with the WCD mounting block and then using chains & sprockets to get to the other wheels. Pic show concept - brown items are the chains (not belts).
Definitely planning some sort of chain guard/cover. |
