Go to Post Anyone riding a Segway looks cool...ask Andy Baker - Kyle Love [more]
Unread 26-11-2014, 14:48
magoldsm magoldsm is offline
Lead Mentor
AKA: Michael Goldsmith
FRC #2635 (Lake Monsters)
Rookie Year: 2012
magoldsm is an unknown quantity at this point
Motor Controller Temporal Resolution
In Aerial Assist, the Lake Monsters used an electric catapult. Instead of a physical stop, we had software monitor the position of the catapult arm and apply full reverse power when the desired release point was reached. We struggled with repeatability. Sometime after the end of the season it dawned on us that we could not achieve the 1-millisecond accuracy of braking that we needed because the PWM input to the Talons has an input rate of (as I recall) about 4 milliseconds. This means it could take anywhere up to 4 milliseconds for the Talon to "notice" that the input signal has changed. This resulted in an uncertainty of release angle of about 2 degrees which was more than enough to spoil our longer shots.
For the future, we were wondering about the resolution when controlling a Jaguar or the new Talon SRX using CAN. Does anyone have any idea how quickly these devices will respond to a CAN motor command?
Thanks!
Michael Goldsmith
2635 Lead Mentor
Unread 29-11-2014, 22:14
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Rookie Year: 2010
adciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to all
Re: Motor Controller Temporal Resolution
In labview, it looks like it will be updated at 20ms (10 for the Talon SRX) if I'm reading the code correctly. You may be able to set this yourself in code. WRT the repeatability you were seeing, can you explain the setup (PWM/CAN) and programming language you were using?
Originally Posted by texarkana View Post
I would not want the task of devising a system that 50,000 very smart people try to outwit.
Unread 30-11-2014, 07:08
I believe all the speed controllers update at 5ms except for the legacy Victor, which was at 10ms. If you look at the diagram of the various motor control Open nodes, you'll see them us 1x, 2x, or 4x as their period multiplier. This is in 5ms increments.
Greg McKaskle
Unread 30-11-2014, 10:39
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
For anyone confused at home, adciv gave the update rate for CAN on the roboRIO, (ie how often the roboRIO will send a new command) and Greg gave the update rate for PWM on the roboRIO. On the cRIO, by default, only the jaguar used 5ms for PWM.
Michael, what kind of sensor did you use for the catapult position? Correct me if I'm wrong, but if you could get the catapult to stop at the right position, it wouldn't matter what the temporal resolution is, right?
Unread 30-11-2014, 10:44
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Thanks Joe. I was in the middle of fact-checking when you posted this.
Unread 30-11-2014, 11:24
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is offline
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
Thanks!
Michael Goldsmith
2635 Lead Mentor
I'm curious of the speed of your shooter or the length of the arm that would give you a 2 degree variation over a few ms.
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
