Go to Post The best way to win an award is to not try to win an award. - MrTechCenter [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 30-11-2014, 13:05
Cash4587's Avatar
Cash4587 Cash4587 is offline
Mentor
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Team Role: Coach
Rookie Year: 2013
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
SolidWorks 2014 Setup
My team recently received our license for 2014-2015 SolidWorks and we are trying to set it up. We are having trouble setting default templates for creating parts, drawings and assemblies. I've looked around on Google and on CD, but have had no luck, I have even tried the SolidWorks forums. Is there any way that somebody could provide general FRC templates for our team to use that are in IPS units, and additionally provide instructions on how to set them as the default templates?
All help is appreciated. Thanks
Unread 02-12-2014, 12:23
adengler's Avatar
adengler adengler is offline
Mr. Dengler
AKA: Aaron Dengler
FRC #2090 (Buffnblue)
Rookie Year: 2007
adengler will become famous soon enough
Re: SolidWorks 2014 Setup
Here are the general steps (from memory)
Create a New Part doc.
Select Options menu, then Document tab
Click Units, change to IPS
Close Options
Select SAVE AS in the File menu
Enter name of your Part template
Select "Save As Template"
To create an Assembly Template, start with a new assembly file and follow the same steps as above. The new templates will be available in the Templates tab of the New Part/Assembly window.
2090 BuffnBlue | Punahou School | Honolulu, HI
Unread 02-12-2014, 13:13
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
I actually wrote a blog post about this for my day job. This should help you out.
http://www.sparxeng.com/blog/mechani...mplates-part-1
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
Unread 02-12-2014, 22:50
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
I have attached our default part templates. My preferred method for setting them is putting them in a dropbox folder, and then setting that folder to a templates location folder in Options(top left corner, blue box) -> File Locations. That way, if you make updates to the templates it updates for everyone CADding.
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
