| Thread Tools |
Rating:
Display Modes |
#16
Re: pic: 3 CIM WCD Ball Shifter CAD
On the upper CIM, your mounting screws are horizontal. Instead of trying to pull out the screw, gravity will deform the gearbox plate and swing the motor down. Last year, I did a simple stress analysis on a couple of our gearbox plates in SolidWorks that were really revealing with motor placement/plate design. I'll see if I can post some screenshots from those to show you what I'm talking about. |
#18
https://scontent-a.xx.fbcdn.net/hpho...e9&oe=54D168FA |
#19
Might just be the angle of the render , but it to me looks like those 4 bolts are in a horizontal line. This won't help; the weight of the gearbox and CIMs would be cantilevered on those 4 bolts. Adding 2 bolts above or below those 4 will add much more strength.
#20
I modified my gearbox plate to look more like yours and did a simple factor of safety analysis. A lower factor of safety corresponds to more load on the material, and a greater deformation of the part.
You could likely get away with what you have drawn up, but some simple improvements will yield huge strength increases. The biggest change you should make is using the 0.75" boss on the front of the CIM to help locate the CIM. It'll increase the positional accuracy of the CIM by quite a bit, and it'll make the part even stronger. All tests were done with the the mounting holes as fixed geometry, and the only load was gravity acting on the 2.82 pound CIM motor. You can roughly double the strength of the part while adding about 0.03 pounds. You can also see why having a convex outline helps too. http://imgur.com/a/xTIpW This is what we came up with last year for a 3 CIM configuration: http://imgur.com/DSjie1M Last edited by Jared : 01-12-2014 at 17:13. |
#21
![]() I will consider these images when modifying the design. What software did you use for this? EDIT: Quote:
#22
Honestly I think it's best practice to design a gearbox as if it was made from solid plate, then lighten after the fact. So the outline of the gearbox is defined by the edge of the CIMs, etc - then remove material. Right now it looks like you're making webs and connecting them, and it's a lot easier to mess that up than it is to go the other way. Correct me if I'm wrong though.
For those reading who want to learn, more on pocketing in this great video: https://www.youtube.com/watch?v=wGmsnD0KQMs Last edited by Chris is me : 01-12-2014 at 18:19. |
#23
I start with a layout sketch of center to center distances, and use it to make a second sketch with outlines for bolt holes and bearings. Next, I draw in the webs as just single lines, usually between the center of two circles. I use the offset tool to create the outline of the webs. In the same sketch, I also draw the outline of the gearbox and use the offset tool again to give it thickness. Finally, I fillet and mirror everything. How else are people doing it? I really like the method described in the video. Here's an example of my normal approach: http://imgur.com/a/gXYzS |
#24
The best part about pocketing last is that if you do it and then you indeed do have to change something, you don't have to practically start the whole design all over again. You just suppress / delete the pocketing, make your changes to the original layout sketch, then redo the pocketing in a new feature. Sometimes you don't even have to redo it. Last edited by Chris is me : 01-12-2014 at 18:45. Reason: Wording clarification and all that |
#25
On lightening:
I've tried a few different styles and I use something similar to Bryce's method nowadays. However, I start with a huge plate, cut all the holes, and then I draw lines connecting the holes and offset them. Then I cut away all the parts that aren't connecting beams or clearances around the holes. I fillet at the end. I would love to see your ballshifting shaft. It might be harder to make than you realize if it's in one piece. |
#26
We try to go with thinner plates, and skip pocketing alltogether, so the style lends itself well to that as well. I hate parts blowing up on changes, so the connect the dots method is a no go for me. Granted. I'm a grumpy jerk and hate tedious/manual CAD methods. I don't have the energy to brute force with dumb methods like I used to when I was younger. |
#27
I figure, if we're going to use a CNC machine to cut the plates, we may as well pocket them. I've found that if you use formulas for as many dimensions as possible, use constraints to eliminate as many dimensions as possible, and use rule fillets instead of manual ones, then most changes won't take nearly as much effort. |
#28
I wasn't sure if you saw, but do you have a an isometric view of the ballshifter shaft? |
#29
https://fbcdn-sphotos-f-a.akamaihd.n...d4841aad532276 |
#30
