| Thread Tools |
Rating:
Display Modes |
#31
Re: pic: 3 CIM WCD Ball Shifter CAD
Related to this component, if you make the hex shaft attach to the ball shifter with a pin or through bolt instead of making it one part it would make removal of the gearbox pretty simple. Just pull the pin, retract the shaft toward the outside of the robot and pull the gearbox either out the top or bottom. Quote:
#32
We used 0.752" without problems last year, allthough it was sort of by accident- I plunged with a 0.75" end mill in place of a 5/8" and thought I screwed up. But it fit perfectly! So plunging in with a good 0.75" endmill produces an almost-perfect hole, although boring or even better over-sized reaming would be preferred if you can manage it. They have 0.751" reamers on the market for a really good fit. |
#33
The pressed in output hex shaft is. But the actual ball shaft is steel.
#35
Also, here is a picture of an updated version that uses some of the suggestions posted in this thread: https://scontent-b-sjc.xx.fbcdn.net/...e4&oe=551455E2 Thanks for everything so far. Questions and comments are still welcome of course! Last edited by Bryce2471 : 02-12-2014 at 02:04. Reason: forgot something |
#36
![]() Last edited by R.C. : 02-12-2014 at 02:03. |
#37
![]() Do you know if vex did any tests that suggest the ball carrier needs to be steel? My team built a ball shifter for our shooter last year. (I'll admit it's a different situation) We experienced that the ball carrier had the least wear out of the three shifter components. Last edited by Bryce2471 : 02-12-2014 at 02:19. |
#38
I was not referring to that part in this instance. the part I am talking about currently is what surrounds the plunger. |
#40
Ah. I just realized that.
#41
Seeing the support of the CIM in more detail makes me more comfortable in it - I guess it's just my personal preference to have a member follow the outer edge of the CIM to best support the face. You're probably good to go with what you have. Last edited by Chris is me : 02-12-2014 at 10:50. |
#42
I'm sure that adding a member would increase strength, but after the revisions I posted, I think it would be unnecessary in this case.
#43
If you need to fix fillets, like Adam displayed in his video, you can use the fillet tool to do face fillets that will bridge the intersection of faces where two fillets intersect. Then you don't need to sketch anything. Last edited by Cory : 02-12-2014 at 14:44. |
#44
Excellent point. I made all our gearbox plates last year to somewhere between 0.750 and 0.751, and only one CIM motor we had fit. We found it interesting that our CIM motors that were 8-10 years old fit perfectly in the 0.750" plate, but the news ones all seemed to be a touch bigger.
#45
What gear sizes did you end up using on this gearbox?
