Go to Post you should be putting forth you best effort every time you enter the field. - Protronie [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 01-12-2014, 22:00
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
Rookie Year: 2011
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Fitting belts within your frame
I'm currently designing a prototype frame for possible adaptation in the coming FRC season. To save space, I'm looking to run one of the 15mm belts on each side of the drive train inside of the frame element itself. I know this is commonly done with 9mm belts, but to stay on the safer side I figured we should design for 15mm. The problem I'm having is I'd like to stay with 2 inch x 1.5 inch frame without having to move up to 3 x 1.5, and this mean the only HTD pulley I can fit (accounting for a center wheel drop of 1/8 inch) in the frame is a 18T one. The 24T is just a bit too big from my calculations.
Also if it matters I'd like to do this all exact C-C. I've heard it works well and we do have access to machining that is accurate down to the thousandth, so I think its the best solution.
My question is whether or not 18T pulleys are big enough to handle the loads that an average drive train subjects them to. Has anyone used 18T pulleys on their drive train? Is 9 teeth of engagement enough?
As a side note, I'm also wondering if 6063 aluminum is good to use for frame elements over 6061. Online its about half the price, so I'm hoping we could use that since we would probably be able to buy more stock.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
