Go to Post I don't know, there's quite a few teams that apply to travel to some random HS gym in Indiana every summer. - GaryVoshol [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
  #16   Spotlight this post!
Unread 02-12-2014, 16:25
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
Rookie Year: 2011
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Re: Fitting belts within your frame
Originally Posted by Joey Milia View Post
22t is the absolute largest you can fit in 2in 1/8 wall tubing. We offset the baseplate rivets from the belts and we do the center drop by pushing the outer wheels up 1/16 and the middle wheel down a 1/16th. I think if you did it all from just the center or just the outer you would get some rubbing. Going 3/32 either side of center to get 3/16 total should be possible though. (please check in CAD though I haven't looked at it for a while)
We chose to go with 2x2 instead of 2x1.5 because of how tight the belts are in the tube. 1.5 doesn't leave much room for things poking into the side of the tube (like gearbox bolts or the caps for access holes) and we were worried about rubbing the sides of the tubes.
Yeah, this sounds like a good option. Makes life a lot easier since we're not at the point where we can make our own gearboxes yet and all the Vex shifters are designed to easily mount onto a 2 in height frame member.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
  #17   Spotlight this post!
Unread 02-12-2014, 16:45
chrisfl chrisfl is offline
FRC #1991 (Dragons)
Team Role: Leadership
chrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to all
Would you be able to create a slot in the top and bottom of the tube to allow clearance for the pulley to extend out of the tube a bit? Then the belt would be going along one or two outer sides of the tube. I haven't done this before. This would help save space within the interior of your frame for electronics and subsystems.
  #18   Spotlight this post!
Unread 02-12-2014, 16:55
Mike Marandola Mike Marandola is online now
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
If I am understanding what you are saying correctly, you wouldn't be able to get the belt in since it can't be split. Unless you are talking about making one long cutout running the length of the tubing. In that case, a lot of strength will be lost.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
