#16
Re: pic: 3 CIM WCD Ball Shifter Second Edition
The reason why I'm not a huge fan of using all bolts connected to CIMs is during assembly you either: a) Have to assemble with CIMs to hold the gearbox together or b) Put it together and put nuts in the back, then when putting in CIMs having to take each nut off. Nothing crazy revolutionary but could make your life easier. |
#17
It doesn't hurt that much to add different mounting holes for the cims. Plus, then you can use a system like what 192 used to tension gearbox belts this year to allow for different pinions to be mounted. We tried assembling WCP gearboxes. It took us around five hours to assemble two gearboxes due to some unforseen issues. It's a great gearbox design for teams with little manufacturing resources. But some parts, like the sping washers, are really annoying to work with if you have enough machining resources to make it fit properly. Also, R.C, if you are reading this, there was a slight error in the instuction manual. A 1/32" spacer is explicitly stated to be a 1/16" spacer in the instuctions. Not sure if that's our problem or something wrong with the manual. |
#19
I'm not a fan of the spring wave either, it'll be replaced out to a solid washer in the future here soon... I'll take a look and your more than welcome to email me here. Please email me what gearbox you were using and which manual etc.. That way we can take care of the typo. Thanks |
#20
I will shoot you an email just as soon as my team has its next meeting. |
#21
As others have mentioned, bearing bore gears and shoulder bolts will save you some weight and bearings. You can even bore out a smaller gear to accept smaller OD bearings.
about the above - sorry, misunderstood gearbox initially. I see the gears on the right idler gear now, for some reason I thought another shaft was buried in there. In this case, I would just like to comment on the use of a 12T CIM pinion as an idler - this may not work well particularly if the pinion is aluminum. A lot of force going through a tiny gear. That's not to say it's impossible or not doable, just be careful. Personally I like this design a lot better than the previous revision. The extra gear is a thing, yes, but the design is more symmetrical, compact, and in many ways simpler. Just seems more elegant to me. Last edited by Chris is me : 08-12-2014 at 16:21. |
