Go to Post The greatest lesson we can teach our kids is how to win. - AdamHeard [more]
Unread 05-12-2014, 10:24
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
Rookie Year: 2012
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Steering a Swerve
So as we continue our development of a swerve module we have just a few (hopefully) sticking points. The biggest is how much torque is normally required to turn a module and hold it in place while driving.
We are thinking about a pg71 http://www.andymark.com/product-p/am-0914.htm gear box with a 1:1 to turn the module itself. Is this in the ball park? What kind of setup do you all use to turn and hold your modules in position?
Is there a calculation that is used...we are a bit stuck.
Unread 05-12-2014, 10:38
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
Rookie Year: 2011
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Re: Steering a Swerve
Search on CD a bit more, I think I remember someone asked this not too long ago here (Post #14): http://www.chiefdelphi.com/forums/sh...hreadid=131261 For starters look at what 1640 did. They have a very well documented module. I would think a pg 71 with the RS 775 type is not enough however a AM9015 at 188:1 (PG188) will for sure.
Also look at this: http://www.chiefdelphi.com/media/papers/2426
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 05-12-2014, 19:26
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
See thsi thread for calculations:
http://www.chiefdelphi.com/forums/sh...d.php?t=129105
Unread 05-12-2014, 21:46
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
Rookie Year: 1996
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
I've found 100 RPM to be a pretty good target for an FRC swerve steering rate...a PG71 with a 2:1 ratio will get you close and provide plenty of steering torque.
The robot in this video is running this setup. It's lighter than a fully loaded FRC setup, but we've used the same setup on heavier machines with favorable results.
Medical hoist with PG71 steering for swerve.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
