Go to Post We may not have any Paris Hiltons around here (though I've heard Paul Copioli is a great kisser) - AndyB [more]
Unread 05-12-2014, 21:19
FRC Team CC FRC Team CC is offline
FRC #6560 (Charging Champions)
Rookie Year: 2012
FRC Team CC is an unknown quantity at this point
[FTC]: Field Control System Not Working
Dear Chief Delphi,
We are the Charging Champions, a six-member rookie team from SoCal. Our teleop program works fine on the RobotC joystick function but when we tested our program on the Field Control System, the robot started to act quite weirdly - the right set of wheels started to move even when we did not move the joystick thumbstick.
Here is the program:
Code:
#pragma config(Hubs,  S1, HTMotor,  HTMotor,  HTServo,  HTMotor)
#pragma config(Motor,  mtr_S1_C1_1,     rightTopDrive, tmotorTetrix, openLoop)
#pragma config(Motor,  mtr_S1_C1_2,     rightBottomDrive, tmotorTetrix, openLoop)
#pragma config(Motor,  mtr_S1_C2_1,     brush,         tmotorTetrix, openLoop)
#pragma config(Motor,  mtr_S1_C2_2,     pulley,        tmotorTetrix, openLoop)
#pragma config(Motor,  mtr_S1_C4_1,     leftBottomDrive, tmotorTetrix, openLoop, reversed)
#pragma config(Motor,  mtr_S1_C4_2,     leftTopDrive,  tmotorTetrix, openLoop, reversed)
#pragma config(Servo,  srvo_S1_C3_1,    basket,               tServoStandard)
#pragma config(Servo,  srvo_S1_C3_6,    brushUpAndDown,       tServoStandard)
//*!!Code automatically generated by 'ROBOTC' configuration wizard               !!*//
#include "JoystickDriver.c" //call joystick functions
task main()
  waitForStart();
	getJoystickSettings(joystick); //call the function
	servo[basket] = 15; // servo basket at 15 degrees
	while(true) //constantly check for the joystick input
		if(abs(joystick.joy1_y1) > 10)// if the absolute value of the left joystick in Joystick 1 is greater than 10
  		motor[leftBottomDrive] = joystick.joy1_y1 * 25/127;// the left-back wheel drives at power 50
  		motor[leftTopDrive] = joystick.joy1_y1 * 25/127;// the left-front wheel drives at power 50
  	else
  		bFloatDuringInactiveMotorPWM = true;//start coasting
  		motor[leftBottomDrive] = 0;//left-back wheel does not move
  		motor[leftTopDrive] = 0;//left-front wheel does not move
  	if(abs(joystick.joy1_y2) > 10)// of the absolute value of the right joystick in Joystick 1 if greater than 10
  		motor[rightBottomDrive] = joystick.joy1_y2 * 25/127 ;// the right-back wheel drives at power 50
  		motor[rightTopDrive] = joystick.joy1_y2 * 25/127;// the right-front wheel drives at power 50
  	else
  		motor[rightBottomDrive] = 0;//right-back wheel does not move
  		motor[rightTopDrive] = 0;//right-front wheel does not move
  	if(joy2Btn(4) == 1 || joy1Btn(4) == 1) //if joystick button Y is pressed
  		motor[brush] = 70;// brush will spin at power 70
  	else
  		bFloatDuringInactiveMotorPWM = false;
  		motor[brush] = 0; //motor will not spin
  	if(joy2Btn(5) == 1) //if Joystick button LB is pressed
  		servo[brushUpAndDown] = 255;// brush goes up the arm
  	else if(joy2Btn(6) == 1)// if Joystick button RB is pressed
  		servo[brushUpAndDown] = 0;// brush goes down the arm
  	if(joystick.joy2_TopHat == 0)// if the "North" button on Tophat is pressed
  		servo[basket] = 230;// basket lifts up
  	if(joystick.joy2_TopHat == 4)//if the "South" button on Tophat is pressed
  		servo[basket] = 115;// basket drops down
  	if(abs(joystick.joy2_y1) > 5 && abs(joystick.joy2_y2) > 5)// if the absolute value of both joysticks in Joystick 2 is greater than 5
  		motor[pulley] = (joystick.joy2_y1 + joystick.joy2_y2) * 25/128;//pulley goes up and down
  	else
  		motor[pulley] = 0;// pulley does not go up or down
Is it a problem with the FCS or is our program not correctly written?
All help is appreciated. Go FTC Teams!!
Thanks,
The Charging Champions
