Go to Post Thankfully, my student drivers are a lot smarter than me and covered for me on several occasions. - Paul Copioli [more]
Unread 05-12-2014, 22:43
FRC Team CC FRC Team CC is offline
FRC #6560 (Charging Champions)
Rookie Year: 2012
FRC Team CC is an unknown quantity at this point
[FTC]: RobotC Coasting Not Working
Hey Chief Delphi,
We are the Charging Champions, a six-member FTC team from SoCal. In our teleop program, we needed to coast our drive wheels (only) since the weight of our robot was causing it to fall backwards every time we stopped. However, after we enabled the bFloatDuringInactiveMotorPWM function for the drive motors, the other motors also started coasting. To prevent this from happening, we turned the function off for the other motors, and ALL of the motors (including the drive motors) stopped coasting.
Here is our code (Note that there are four motors for driving and two for other things):
Code:
#pragma config(Hubs,  S1, HTMotor,  HTMotor,  HTServo,  HTMotor)
#pragma config(Motor,  mtr_S1_C1_1,     rightTopDrive, tmotorTetrix, openLoop)
#pragma config(Motor,  mtr_S1_C1_2,     rightBottomDrive, tmotorTetrix, openLoop)
#pragma config(Motor,  mtr_S1_C2_1,     brush,         tmotorTetrix, openLoop)
#pragma config(Motor,  mtr_S1_C2_2,     pulley,        tmotorTetrix, openLoop)
#pragma config(Motor,  mtr_S1_C4_1,     leftBottomDrive, tmotorTetrix, openLoop, reversed)
#pragma config(Motor,  mtr_S1_C4_2,     leftTopDrive,  tmotorTetrix, openLoop, reversed)
#pragma config(Servo,  srvo_S1_C3_1,    basket,               tServoStandard)
#pragma config(Servo,  srvo_S1_C3_6,    brushUpAndDown,       tServoStandard)
//*!!Code automatically generated by 'ROBOTC' configuration wizard               !!*//
#include "JoystickDriver.c" //call joystick functions
task main()
  waitForStart();
	getJoystickSettings(joystick); //call the function
	servo[basket] = 15; // servo basket at 15 degrees
	while(true) //constantly check for the joystick input
		if(abs(joystick.joy1_y1) > 10)// if the absolute value of the left joystick in Joystick 1 is greater than 10
  		motor[leftBottomDrive] = joystick.joy1_y1 * 25/127;// the left-back wheel drives at power 25
  		motor[leftTopDrive] = joystick.joy1_y1 * 25/127;// the left-front wheel drives at power 25
  	else
  		bFloatDuringInactiveMotorPWM = true;
  		motor[leftBottomDrive] = 0;//left-back wheel does not move
  		motor[leftTopDrive] = 0;//left-front wheel does not move
  	if(abs(joystick.joy1_y2) > 10)// of the absolute value of the right joystick in Joystick 1 if greater than 10
  		motor[rightBottomDrive] = joystick.joy1_y2 * 25/127 ;// the right-back wheel drives at power 25
  		motor[rightTopDrive] = joystick.joy1_y2 * 25/127;// the right-front wheel drives at power 25
  	else
  		motor[rightBottomDrive] = 0;//right-back wheel does not move
  		motor[rightTopDrive] = 0;//right-front wheel does not move
  	if(joy2Btn(4) == 1 || joy1Btn(4) == 1) //if joystick button Y is pressed
  		motor[brush] = 70;// brush will spin at power 70
  	else
  		bFloatDuringInactiveMotorPWM = false;
  		motor[brush] = 0; //motor will not spin
  	if(joy2Btn(5) == 1) //if Joystick button LB is pressed
  		servo[brushUpAndDown] = 255;// brush goes up the arm
  	else if(joy2Btn(6) == 1)// if Joystick button RB is pressed
  		servo[brushUpAndDown] = 0;// brush goes down the arm
  	if(joystick.joy2_TopHat == 0)// if the "North" button on Tophat is pressed
  		servo[basket] = 230;// basket lifts up
  	if(joystick.joy2_TopHat == 4)//if the "South" button on Tophat is pressed
  		servo[basket] = 115;// basket drops down
  	if(abs(joystick.joy2_y1) > 5 && abs(joystick.joy2_y2) > 5)// if the absolute value of both joysticks in Joystick 2 is greater than 5
  		motor[pulley] = (joystick.joy2_y1 + joystick.joy2_y2) * 25/128;//pulley goes up and down
  	else
  		motor[pulley] = 0;// pulley does not go up or down
Did we use the bFloatDuringInactiveMotorPWM function incorrectly? If so, what is the correct way to use?
All help is appreciated. Go FTC TEAMS!!!
Thanks,
The Charging Champions
Unread 06-12-2014, 13:44
Rookie Year: 2012
Re: [FTC]: RobotC Coasting Not Working
Are there any alternatives to using bFloatDuringInactiveMotorPWM since this feature turns coasting on or off for the whole program (not for each specific motor)
Thanks,
Unread 09-12-2014, 10:05
MaxMiller117 MaxMiller117 is offline
FTC #3888
MaxMiller117 is an unknown quantity at this point
Based off of the motor controller specifications, a value of -128 sets the motor to off/float instead of off/brake. I have not tested this though.
http://www.hitechnic.com/blog/wp-con...cification.pdf
