Go to Post A Red Ryder 200-shot carbine Range model air rifle!!! - dlavery [more]
  #16   Spotlight this post!
Unread 09-12-2014, 18:51
audietron's Avatar
audietron audietron is offline
Red for mediocre performance
AKA: Grayson Burgess
FRC #0965 (X3 Robotics)
audietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to behold
Re: pic: KING TeC Drivetrain Prototype - All Wired Up!
Originally Posted by Thad House View Post
I would recommend something similar to Chezy Drive. We've been using Chezy Drive for the past 3 years.
What is Chezy drive?
2015: Galileo Semifinalists
2015: North Star Regional Finalists (Thanks to 5576 and 2531)
2014: North Star Semifinalist (Thanks to 2175 & 4607)...again
2014: Central illinois Semifinalist (Thanks to 1756 & 1288)
2013: North Star regional Winner (Thanks to 2175 & 4607)
2013: Curie Semifinalist (Thanks to 2056 & 3990)
2013: IRI Semifinalist (Thanks to 359, 1477, & 148)
  #17   Spotlight this post!
Unread 09-12-2014, 18:55
Thad House Thad House is offline
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
Its a modified arcade drive. They use 2 separate joysticks. One to control throttle, and one to control turning. Some math actually changes the turning ratio so the robot turns in smooth arcs instead of sharp corners like standard arcade drive would. This makes full speed sweeping turns much easier, which makes the robot more controllable.
Their implementation can be found here.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
  #18   Spotlight this post!
Unread 09-12-2014, 18:58
audietron's Avatar
That is essentially what we use but I just called it halo drive. I might just implement the "smooth arc" changes to our drive though to see what that is like.
  #19   Spotlight this post!
Unread 09-12-2014, 20:13
audietron's Avatar
do you have video of the drive running?
  #20   Spotlight this post!
Unread 10-12-2014, 21:47
AKSoapy29's Avatar
AKSoapy29 AKSoapy29 is offline
Driver, Prog, Elec, Pneu, Etc.
AKA: Andrew K.
FRC #2169 (KING TeC)
AKSoapy29 has a spectacular aura aboutAKSoapy29 has a spectacular aura aboutAKSoapy29 has a spectacular aura about
Of our prototype drive, yes. Our video guy won't be able to render it immediately though :/
And just a linear drive is a bit to uncontrollable, so we are going to try to test out some different math functions for the different gears and see what handles the best.
  #21   Spotlight this post!
Unread 12-12-2014, 10:15
Jay Burnett Jay Burnett is offline
FRC #5332 (Toaster Tech)
Team Role: Leadership
Jay Burnett is an unknown quantity at this point
How do you guys hold the wheels on to the shafts at the end? I'm designing a WCD for our team and was curious how other teams accomplished this.
  #22   Spotlight this post!
Unread 12-12-2014, 11:33
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is offline
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
Our team, and I'd imagine most teams, uses snap rings.
  #23   Spotlight this post!
Unread 12-12-2014, 12:10
Really? That's what i have in the CAD now, but I was told that those might not hold up under the force of the wheel trying to push off the shaft. Any specific type? Thanks!
  #24   Spotlight this post!
Unread 12-12-2014, 12:17
audietron's Avatar
We use klip rings which are a brand name type ring. They are a special type of e-clip but easy to put on and take off with a screwdriver.
Here is the link to them:
www.mcmaster.com/#98420a138/=uzrf5a
  #25   Spotlight this post!
Unread 12-12-2014, 13:12
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
They are rated for a lot of force, and unless the snap ring is damaged by deforming too much during installation (easy to avoid with proper snap ring pliers) they are plenty for the job.
