Go to Post I think I wanna buy a Segway just to throw myself in the air to see what would happen... - Elgin Clock [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 08-12-2014, 20:38
RaiderRobotics RaiderRobotics is offline
FRC #5024
RaiderRobotics is an unknown quantity at this point
cannot upload code to cRIO.
One of our laptops died and we're trying to replace it with two new ones.
I've downloaded Netbeans and installed the 6 FRC plugins, and set our team code (5024). I've also downloaded and installed the FRC2014UpdateSuite6.00.zip
We can connect with the cRIO. The cRIO imaging tool shows that it is running FRC_2014_v52. This also shows up in the listbox under the "format controller" check box. (so the zip file is in the correct place (.../sunspotfrcsdk/cRIO_images).
When we try and compile and upload a program we get the following error:
(this last time we are just trying a simpleRobot instead of IterativeRobot)
Code:
ant -f C:\\Users\\User\\Documents\\NetBeansProjects\\SimpleRobotTemplate deploy run
init:
init:
Deleting directory C:\Users\User\Documents\NetBeansProjects\SimpleRobotTemplate\build
Deleting directory C:\Users\User\Documents\NetBeansProjects\SimpleRobotTemplate\suite
Deleting directory C:\Users\User\Documents\NetBeansProjects\SimpleRobotTemplate\j2meclasses
clean:
Created dir: C:\Users\User\Documents\NetBeansProjects\SimpleRobotTemplate\build
Compiling 1 source file to C:\Users\User\Documents\NetBeansProjects\SimpleRobotTemplate\build
warning: [options] source value 1.3 is obsolete and will be removed in a future release
warning: [options] target value 1.2 is obsolete and will be removed in a future release
warning: [options] To suppress warnings about obsolete options, use -Xlint:-options.
3 warnings
compile:
Created dir: C:\Users\User\Documents\NetBeansProjects\SimpleRobotTemplate\j2meclasses
preverify:
Created dir: C:\Users\User\Documents\NetBeansProjects\SimpleRobotTemplate\suite
Building jar: C:\Users\User\Documents\NetBeansProjects\SimpleRobotTemplate\suite\SimpleRobotTemplate_1.0.0.jar
jar-app:
CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes
CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt
CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods
[translating suite image [closed: false, parent: squawk] ...]
### Excluding compile: com.sun.squawk.SymbolParser::getSignatureTypeAt
### Excluding compile: com.sun.squawk.Method::getParameterTypes
[Including resource: META-INF/MANIFEST.MF]
Romizer processed 96 classes and generated 4 files.
Expanding: C:\Users\User\Documents\NetBeansProjects\SimpleRobotTemplate\suite\SimpleRobotTemplate_1.0.0.jar into C:\Users\User\Documents\NetBeansProjects\SimpleRobotTemplate\suite
Moving 1 file to C:\Users\User\Documents\NetBeansProjects\SimpleRobotTemplate\suite
Deleting: C:\Users\User\Documents\NetBeansProjects\SimpleRobotTemplate\image.suite.api
Host OS: Windows 7 6.1, 6.1
Host JVM: Java HotSpot(TM) 64-Bit Server VM 25.20-b23
Target IP: 10.50.24.2
Network interfaces on host:
    Intel(R) WiFi Link 5100 AGN:  address: 10.50.24.50 netmask: 255.255.255.0 <--- on robot's subnet
Connecting FTP @10.50.24.2
C:\Users\User\sunspotfrcsdk\build.xml:96: The following error occurred while executing this line:
C:\Users\User\sunspotfrcsdk\ant\upgrade.xml:39:
java.net.SocketException: Software caused connection abort: socket write error
	at java.net.SocketOutputStream.socketWrite0(Native Method)
	at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:109)
	at java.net.SocketOutputStream.write(SocketOutputStream.java:153)
	at sun.nio.cs.StreamEncoder.writeBytes(StreamEncoder.java:221)
	at sun.nio.cs.StreamEncoder.implFlushBuffer(StreamEncoder.java:291)
	at sun.nio.cs.StreamEncoder.implFlush(StreamEncoder.java:295)
	at sun.nio.cs.StreamEncoder.flush(StreamEncoder.java:141)
	at java.io.OutputStreamWriter.flush(OutputStreamWriter.java:229)
	at java.io.BufferedWriter.flush(BufferedWriter.java:254)
	at org.apache.commons.net.ftp.FTP.__send(FTP.java:505)
	at org.apache.commons.net.ftp.FTP.sendCommand(FTP.java:479)
	at org.apache.commons.net.ftp.FTP.sendCommand(FTP.java:608)
	at org.apache.commons.net.ftp.FTP.port(FTP.java:932)
	at org.apache.commons.net.ftp.FTPClient._openDataConnection_(FTPClient.java:812)
	at org.apache.commons.net.ftp.FTPClient._retrieveFile(FTPClient.java:1854)
	at org.apache.commons.net.ftp.FTPClient.retrieveFile(FTPClient.java:1845)
	at com.sun.spot.sdk.tool.ftp.UpgradeTask.checkVersion(UpgradeTask.java:34)
	at com.sun.spot.sdk.tool.ftp.UpgradeTask.execute(UpgradeTask.java:215)
	at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:292)
	at sun.reflect.GeneratedMethodAccessor132.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:483)
	at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
	at org.apache.tools.ant.Task.perform(Task.java:348)
	at org.apache.tools.ant.Target.execute(Target.java:435)
	at org.apache.tools.ant.Target.performTasks(Target.java:456)
	at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1393)
	at org.apache.tools.ant.helper.SingleCheckExecutor.executeTargets(SingleCheckExecutor.java:38)
	at org.apache.tools.ant.Project.executeTargets(Project.java:1248)
	at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:441)
	at org.apache.tools.ant.taskdefs.CallTarget.execute(CallTarget.java:105)
	at org.apache.tools.ant.Project.executeTarget(Project.java:1364)
	at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
	at org.apache.tools.ant.module.bridge.impl.BridgeImpl.run(BridgeImpl.java:286)
	at org.apache.tools.ant.module.run.TargetExecutor.run(TargetExecutor.java:555)
	at org.netbeans.core.execution.RunClassThread.run(RunClassThread.java:153)
BUILD FAILED (total time: 7 seconds)
  • Is there any way to do this manually and FTP the code to the cRIO?
  • Is this because it is trying to go to a webpage that doesn't exist anymore (NI has pulled some of their webpages, so we can't get updates)
  • I have tried copying the complete sunspotfrcsdk folder over from our one working laptop. But that doesn's solve the problem.
Thanks.
Unread 08-12-2014, 20:40
FRC #5024
Re: cannot upload code to cRIO.
P.S. This is the section in the \ant\upgrade.xml file that fails:
Code:
<target name="-do-upgrade">
        <frcupgrade
            remoteaddress = "${remoteaddress}"
			localotaserverfile="${sunspot.home}/cRIO/FRC_UserProgram.out"
			remoteotaserverfilepath="/ni-rt/system/FRC_JavaVM.out"
            localvmfile = "${sunspot.home}/cRIO/squawk.out"
            remotevmfilepath="/ni-rt/system/squawk.out"
            localsuitefile = "${sunspot.home}/cRIO/squawk.suite"
            remotesuitefilepath = "/ni-rt/system/squawk.suite"
            remoteversionfilepath = "/FRC_ImageVersion.ini"
            versionfailuremessage = "Go to http://first.wpi.edu/FRC/frcjava.html to get latest software update">
            <version name="Name" value="FRC_2014_v52.zip;"/>
            <version name="Language" value='"Java;"'/>
        </frcupgrade>
    </target>
Unread 08-12-2014, 20:47
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Make sure all firewalls on your laptop (you really only need one firewall) have are either disabled (if the laptop isn't ever going to be connected to the internet) or have explicit exceptions for Netbeans and anything else related to the FRC Control System.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 08-12-2014, 20:57
chsahit's Avatar
chsahit chsahit is offline
Lead Developer
AKA: Sahit C
FRC #0011 (MORT)
Rookie Year: 2013
chsahit will become famous soon enoughchsahit will become famous soon enough
Do you have communications with the cRIO over the Driver Station? If not did you remember to hard set your IP address (10.50.24.<whatever>) and Subnet Mask(255.255.255.0)? Can you ping the cRIO (10.50.24.2)? This is clearly a problem with networking and not with code.
Unread 08-12-2014, 21:56
FRC #5024
Yes, as far as I can recall (being at home now) we can run the robot using the Driver Station just fine.
I should have thought about the firewalls. ... Yep. It's on. $@#$@#$@#$@#. I'll try again tomorrow back at school.
