Go to Post You are what this world needs: a hero kids of all ages and backgrounds can look up to. I am a better person today than before I met you, because of how you touched my life. I thank-you. - Paul Copioli [more]
Unread 13-01-2015, 10:07
Sh1ine Sh1ine is offline
FRC #2791
Team Role: Leadership
Sh1ine is on a distinguished road
Re: Encoders for 2015 Season
Originally Posted by Qbot2640 View Post
Excuse my lack of experience - we have never used encoders, and I desperately want to this year. The Grayhill models referenced above look like potentiometers, for lack of a better description...How are they installed? Do you just couple the shaft to the gearbox shaft?
I understand how the US Digital one's install - in fact, we installed a pair on our robot this fall for the off-season, but never figured out how to wire them up or program them.
We use Grayhill Encoder 63R128 (http://www.digikey.com/product-detai...3069-ND/304478) They are terrific encoder, and Digi key sells them at a good price. We use 128 count encoders for our drive train, and since we have them laying around, they get used for other systems frequently as well. In order to to attach our encoder to our output shaft we use 1/4 OD and 3/16 ID surgical tubing. It sounds sketchy, but works great, it also helps absorb some slight misalignment issues that you might have. Simply slip the tubing over the .250 part of a AM output shaft and the other side slips onto the encoder. Create a bracket to hold it in place and you are good to go.
Here is an image:
https://drive.google.com/file/d/0B02...ew?usp=sharing
Hope this helps!
Unread 14-12-2014, 22:27
stufflikethat stufflikethat is offline
stufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of light
Originally Posted by AdamHeard View Post
I'm a big fan of US Digital, and use the super high count E6's where it makes sense... but for a shaft based option I'm not seeing the advantage of the H6 over the grayhill encoders. Much more money and size!
Hey Adam would you mind linking me to your preferred grayhill encoder.
Many thanks.
Unread 13-01-2015, 11:43
The_Drive_DR The_Drive_DR is offline
FRC #2036
The_Drive_DR is an unknown quantity at this point
We are using the CUI encoders (http://www.cui.com/product/component...ar/amt10-v-kit) and they work great!
Unread 13-01-2015, 11:51
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
with the Grayhill encoders, how do you wire them? Do you use the same connector as the AM USDigital encoders?
May seem like a dumb question but I am not an electronics guy.
Thanks
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 13-01-2015, 12:35
wmarshall11 wmarshall11 is offline
FRC #2399
Rookie Year: 2011
wmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to behold
Thanks
You can get them with wires attached or with .1in pins. Getting the pins tends to be more feasible. You can either solder to them or attach standard .1 female connectors (same as pwm) and run cable back to your control board.
Unread 13-01-2015, 12:57
Bruceb's Avatar
With the USdigital encoders there were 4 wires, with these I see 5 pins.
What do they get wired to?
Thanks
Unread 13-01-2015, 13:18
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The data sheet shows the pinout. Pin 4 is not connected.
