Go to Post You don't need to prototype everything, just the stuff you want to work. - JVN [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 11-12-2014, 22:23
Vespasian's Avatar
Vespasian Vespasian is offline
AKA: Elliot Dowd
FRC #1511 (Rolling Thunder)
Team Role: CAD
Rookie Year: 2012
Vespasian is an unknown quantity at this point
pic: Team 1511 Prototype Drivebase Mk. II
Unread 11-12-2014, 22:25
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Rookie Year: 2011
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
Re: pic: Team 1511 Prototype Drivebase Mk. II
Consider the momentum of a fast-moving FRC robot. Cylinders aren't really designed to take side loads. Are you concerned about bending those cylinders if hit?
What do you do if you lose pressure? Will the bellypan drop and prevent movement?
Rs775s have been used on drive trains by teams before, but be careful. Running those motors near stall for a long time will fry them- they are fan cooled, as opposed to CIMs, which are passively cooled and rely on a large thermal mass to keep from overheating.
Unread 11-12-2014, 23:32
Oblarg Oblarg is offline
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
How much chain wrap are you getting on that center sprocket if you only have one run of chain per side? That kind of design worries me.
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
Unread 12-12-2014, 19:24
Vespasian's Avatar
AKA: Elliot Dowd
Team Role: CAD
Rookie Year: 2012
They are not shown here, but we plan on using tensioners between each wheel to increase the total chain engagement on the center sprocket. I discussed this with a few of our mentors, and they didn't seem to be concerned. Can I ask what specifically is worrying about that style of chain? I am a bit skeptical of it since we have not used it before, but I don't want to discount it if the concept is valid.
Abhishek R Abhishek R is offline
FRC #0624
Rookie Year: 2012
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
If I remember right, we fried a 775 when we tried using it in conjunction with the CIM-ile on our gearbox this year. Also, am I understanding it right that there is one chain guiding all three wheels? If so, are you worried that the center wheel may not be perfectly aligned with the chain?
2012 - 2015 : 624 CRyptonite
Team Website
Unread 12-12-2014, 00:07
Chris is me's Avatar
AKA: Pinecone
Belly pans, especially metal ones, are generally used to connect members together for more torsional rigidity. If you articulate the belly pan you lose more or less all of the benefits of a metal belly pan but you keep all the weight.
Not to mention, you want to resist pushing matches by exposing all of your electronics to anything at ground level? This can't end well.
Unread 12-12-2014, 00:09
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Interesting. Why are you opting to use a 775 over a minicim or even a cim?
Pocketing the bellypan like that is a bad idea if you're not putting some kind of plastic cover over it to protect the electronics.
Unread 12-12-2014, 00:14
AKA: Pinecone
I've seen dozens of teams and robots with pocketed bellypans and no plastic sheet underneath that did not have any issues with this sort of thing at all. I don't think pocketing a belly pan is a bad idea - debris is rarely coming from straight up underneath your robot.
Unread 12-12-2014, 00:35
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
But in this case they drop the bellypan, so stuff can touch the floor.
You're right, it probably won't affect anything as the force is mainly downwards. Still, my team's mentors would throw a fit if we didn't isolate the electronics.
Unread 12-12-2014, 01:05
philso philso is offline
Mentor
FRC #2587
Rookie Year: 2011
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
As Chris has stated, dropping your belly pan as a brake will cause your chassis to lose most of it's torsional rigidity. One good hit and it will become a parallelogram. You are better off pushing individual pads against the carpet. Several years ago, one of the local teams did this. The pads were about 3 " x 3". They glued the wheel tread material to them. Two adults could not push their robot an inch once they were down.
Omitting the pockets in the gusset plates at the corners will allow them to resist hard hits better.
Do you have a separate picture of the "end caps"? They seem to be integral with the gusset on top and have a flanges that attach to the two plates running from to back on each side. It is difficult to see what they really look like but if they are the way I think they are, it will be very difficult to make the bends.
The plates that the gearboxes are mounted to have the bottom flange removed. There is a lot of mass (motor and gearbox) mounted to the side plate. In a collision, there will be a bending moment that can bend the side plate.
Place real components on your belly pan to check the size of the pocketing. The square holes look like they may be too big, forcing you to space the components out too much or making it such that the electrical components are attached to only one of the webs. More surface area will be needed if Velcro will be used to attach the electronics.
It may be advantageous to omit the holes in the top of the front and rear tubes to allow material so that the upper structure can be attached securely.
The tube across the middle will add more rigidity if it is attached to a plate at each end and those plates attached to the gearboxes in two locations.
Where is the battery mounted and how is it retained?
Is the gearbox easily removable for servicing/repair? Are the bolts that attach the gearboxes easily accessible?
Unread 12-12-2014, 07:41
Dr.Gusta's Avatar
Dr.Gusta Dr.Gusta is offline
FRC #5107 (The Neurotoxins)
Team Role: CAD
Rookie Year: 2014
Dr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of light
Everyone seems to be hitting the major issues but my other gripe is the lack of radius on your pockets. Adding a radius will make it stronger, make it look nicer, and make it easier to manufacture (Lasers, Waterjets, and CNC Mills can not do non radiused inside corners)
Edit: Other than that is a beautiful drive base! Seriously very good job! I feel like some, including myself, forget to say that.
Unread 12-12-2014, 09:43
ThunderousPrime's Avatar
ThunderousPrime ThunderousPrime is offline
All Drive. No Drama.
AKA: Nick Brown
Rookie Year: 2011
ThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to behold
Just to be clear our belly pan does have a piece of corrugated plastic as the surface where we mount our electric and pneumatic components.
This is a picture of the first iteration of the drivetrain which is described in more detail in this thread.
We have discussed doing 4 plates instead of the whole belly pan dropping. Part of the reason why we tried the belly pan idea was that we wanted to see if more surface area of the tread on the belly pan created more friction. The laws of physics says that SA shouldn't matter but that applies to 2 flat surfaces rubbing against each other, not carpet and bumpy wheel tread.
2015: Montreal Regional Chairman's Award
2014: Finger Lakes Regional Chairman's Award, Tech Valley EI
2013: Boston Regional Winners with 125 and 126
2012: Connecticut Regional Engineering Inspiration Award
Unread 12-12-2014, 09:35
Vespasian's Avatar
AKA: Elliot Dowd
Team Role: CAD
Rookie Year: 2012
As for the side loads, it is a concern, but each cylinder only has a stroke of 1" at 5/16" bore. They could bend, but it would take a considerable amount of force. These are relatively easy to replace in this design, though I would rather not have to keep extras lying around, since they're not too cheap.
Currently, there is no redundancy in terms of pressure loss. For our build season design (assuming the game is conducive to this system) we will probably have four smaller "feet" drop down instead of the entire pan. This gives the advantage of having rigidity from the pan, and less room for catastrophic failure. On that note, does anyone have a suggestion on what to do in case of pressure loss? I was thinking maybe surgical tubing to pull against the "feet" or bellypan with just enough force to lift them off the ground.
I have heard many concerns about stalling RS775's for too long and frying them. If they are too much of an issue, we could replace them with Mini-CIM's or just take them out altogether.
Unread 12-12-2014, 11:31
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Even so, the failure mode of this design is a robot propped up that can no longer move. I don't know the likelyhood of bending those pistons, but I would recommend doing heavy destructive testing on it before you consider using the design in a competition. It depends on "when" in a match you would use this though. If it is part of some end game then I would guess that you would be fine. But if they intent is to lock down an area or hold position for long periods of time . . .
That is a good idea. Surgical tubing, springs, or the like are definitely good there.
  #15   Spotlight this post!
Unread 12-12-2014, 11:35
AKA: Eli Barnett
If I were doing any sort of actuated belly-pan, I'd do two things:
1: Don't actuate the actual belly-pan. As has been mentioned, it's a structurally important piece that you will likely want to mount a lot of important electronic/pneumatic components on. Putting that in close contact to the ground is probably not such a great idea. Instead, have a separate pan on the bottom that is actuated - it doesn't have to be very heavy (plywood should work fine).
2: Don't link it directly with the cylinder(s) you use to actuate it. You're much less-likely to bend a cylinder if you design it such that your cylinder pushes a cam that lowers the plate, rather than just linking the cylinder to the plate.
