Go to Post I said it was called FIRST Robotics and the coolest thing I'd seen that day was a 150lb robot balance with another one on a teeter-tooter and and then score basketballs from 30 feet away. - Siri [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 12-12-2014, 11:38
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is offline
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
Re: pic: Team 1511 Prototype Drivebase Mk. II
Originally Posted by Monochron View Post
Even so, the failure mode of this design is a robot propped up that can no longer move. I don't know the likelyhood of bending those pistons, but I would recommend doing heavy destructive testing on it before you consider using the design in a competition. It depends on "when" in a match you would use this though. If it is part of some end game then I would guess that you would be fine. But if they intent is to lock down an area or hold position for long periods of time . . .
That is a good idea. Surgical tubing, springs, or the like are definitely good there.
What about single acting cylinders? They would spring back up when not pressurized.
Unread 12-12-2014, 11:43
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
What thickness sheet metal are you using? Also, do you need the outer wheels to be live axle, or would dead axle work?
Unread 12-12-2014, 19:18
Vespasian's Avatar
Vespasian Vespasian is offline
AKA: Elliot Dowd
FRC #1511 (Rolling Thunder)
Team Role: CAD
Rookie Year: 2012
Vespasian is an unknown quantity at this point
Most of the sheet metal is 1/8" with the exception of the cylinder mounting brackets and the bracket between the inner flanged sheets and the front/back 1x2" tubing (.090"). The outer wheels could be dead axle, we actually did so for the earlier version of this design (which we built: http://www.chiefdelphi.com/forums/sh...readid=131485).
I'm thinking keeping the axle type consistent would be preferable for machining purposes, but that does mean a bit more mass is being directly driven by the transmissions.
Unread 12-12-2014, 13:06
Abhishek R Abhishek R is offline
FRC #0624
Rookie Year: 2012
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
I agree, this seems like it would be a good use for single action cylinders, defaulting to the retracted position for cautionary purposes so you never get stuck. You would save air as well.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 12-12-2014, 14:01
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
Team Role: Coach
Rookie Year: 2010
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
If you do decide to actuate feet rather than the belly pan, a simple hinged element would remove the possibility of side load on your cylinders. Think of a see-saw where the cylinder pushes on a side that isn't in contact with the ground at all.
Also, I agree on this being a perfect place for a single acting cylinder. If you don't have any, a simple spring placed over the rod and one port vented to atmosphere can make a double into a single. You get the unique option of having the opposite direction of your typical single acting cylinder as well.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 12-12-2014, 16:03
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Or an over-center linkage might work if used correctly.
Unread 12-12-2014, 18:20
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
Pneumatic cylinders directly acting on a plate with a short throw will be fine, no reason to over complicate it with a linkage.
Our brake last year was 3x 1" pancake cylinders all attached to a 20x14 plate covered in rough top. Worked great without ever bending the rod on a cylinder.
I will say that you should consider pancake cylinders instead of regular ones from a packaging standpoint they are much nicer for this kind of application.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 12-12-2014, 21:10
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Rookie Year: 2011
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
I'd still use some kind of linkage. It doesn't add that much complexity, and for something where the failure mode is being stuck for the rest of the match, you want a lot of safety.
Unread 12-12-2014, 21:40
I guess....but wouldn't your linkage be just as susceptible to failing in the down position? Call me old fashioned but, I would rather stick 3x 1/2 steel shafts taking the brunt of the impact than some aluminum linkage bracket. Also 1 degree of freedom vs 2+
Unread 12-12-2014, 19:31
Vespasian's Avatar
AKA: Elliot Dowd
Team Role: CAD
Rookie Year: 2012
Thank you to everyone who suggested the single acting cylinder, to be honest I didn't know they existed! This is our team's first time using pneumatics in quite some time.
I just looked up what they are, and it seems they would be perfect for this application.
