Go to Post While youth is wasted on the young, in FRC knowledge can be wasted on those a bit older. - IKE [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 11-12-2014, 23:45
Merfoo's Avatar
Merfoo Merfoo is offline
FRC #0955 (CV Robotics)
Rookie Year: 2012
Merfoo is an unknown quantity at this point
Router Connection Problem
Our router keeps dropping packets. We have tested with 2.4 and 5 gHz and followed FRC router configuration guidelines with the FRC bridge configuration tool and manually. We connected the driver station directly to the cRio which worked. We alos connected the driver station to the router and then that to the cRio, which also worked. We have tested with multiple ethernet cables, computers, routers, and cRios, and also reinstalled wireless drivers. We used a 5gHz dongle which also didn't work. We have ran out of ideas to fix this problem any help would be appreciated.
Unread 11-12-2014, 23:57
markmcgary's Avatar
markmcgary markmcgary is offline
Software Mentor
FRC #4322 (Clockwork Oranges)
Rookie Year: 2012
markmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nice
Re: Router Connection Problem
How do you know that?
Unread 12-12-2014, 00:00
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Rookie Year: 2011
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
I would guess through the "charts" tab of the driver station application, which displays the number of lost packets, battery voltage, and cRIO CPU usage.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 12-12-2014, 00:05
markmcgary's Avatar
Software Mentor
Rookie Year: 2012
Are you having problems controlling the robot through WiFi? Or, are you just concerned about dropped packets being reported on the charts tab?
Unread 12-12-2014, 00:24
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
I'm inferring from your description that everything is fine until you try to make a wireless connection from your Driver Station computer to the robot. Is that an accurate interpretation?
Are you using the D-Link router on the robot? Where is it mounted? Do you have it far from any causes of interference, like a big chunk of metal or a motor or a speed controller?
The 12v-to-5v converter is a large source of radio interference. It's convenient and obvious to mount it right against the router itself, but it's also very very bad.
Unread 12-12-2014, 00:35
Merfoo's Avatar
Rookie Year: 2012
When trying to connect to the router wireless from the driver station no matter where the router is placed we get communication to the robot and then lose it constantly. The connection is never steady.
Unread 12-12-2014, 01:06
feverittm's Avatar
feverittm feverittm is offline
FRC #0997 (Spartans)
Rookie Year: 2010
feverittm will become famous soon enoughfeverittm will become famous soon enough
Given we are in the same school district, I think I might have an idea
I have heard from the IT techs that they installed quite a few more access points around CHS this past summer and it absolutely flooded our WiFi. We moved to another place in the school and were able to connect just fine. I would guess that it is possible that CV is the same. This was especially true in the shop area.
Find someone that has a WiFi scanner on their phone and have them check the signal strength in the area. I would also try moving the robot to another area in the school (try the Cafeteria) and see if the connection is any more stable.
Good Luck!
Floyd Moore
Mentor Electrical and Pneumatics
Team 997 - Spartan Robotics
Corvallis High School, Corvallis Oregon
Unread 12-12-2014, 01:09
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Try using a wifi sniffer, such as inSSIDer to figure out how busy your area is.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 12-12-2014, 01:11
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
FRC #0973 (Greybots)
Rookie Year: 2012
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
Essentially our problem is this.
Perfect comm over ethernet, everything works perfectly.
Attempt Wifi connection, nothing. When we try to ping (CMD) either the router, the Crio or the connecting computer we get a response between 50% (best so far) and 0%. That is the percentage of packets that aren't dropped.
So far, we have
  • Bought new routers
  • Reconfigured 4 different routers
  • Reflashed cRio
  • Tried 3 different cRio
  • Bought a USB network card that can connect on 5Ghz
We only get comms when the occasional packet gets through, never enough to actually see the robot code light go green (over wifi)\
We have tried pinging 10.9.55.1 (router)
10.9.55.2
10.9.55.5 (computer static ip)
Another note is that our robot from last year, which worked then, no longer works and experiences these same issues over wifi.......
We tried 3 different laptops with different wifi cards to no avail...... We even bought a Linksys N600 USB adapter, which ususally fixes interference issues and it didn't help at all.
Help would be appreciated
Good Luck!
We've tried the wifi sniffer, and we agree it is flooded..... 8 different networks exist at strengths of 30db or stronger across all channels.
This is why we tried the 5ghz band with the wireless usb card. Then we noticed long range comms suck....... so we put router and laptop next to each-other. It improved for a bit, then worsened. I also took one of the routers home, and I'll be playing with it once I finish my homework to see if the comms improved.
Our shop could be pretty noisy actually......... We have routers in nearly all the classrooms now and they are arrayed around the shop.... I'll grab a wifi sniffer and take a look in the shop tomorrow, since we only tested it in the classrooms
(2015-?): 973
(2012-2015): 955
Unread 12-12-2014, 01:25
icecube45's Avatar
icecube45 icecube45 is offline
Drive|Programming|Captain
FRC #0114 (Eaglestrike)
Team Role: Driver
Rookie Year: 2013
icecube45 is a jewel in the roughicecube45 is a jewel in the roughicecube45 is a jewel in the roughicecube45 is a jewel in the rough
This happened to us last year, and as others above me have stated, it was due to our wifi being flooded... I wish I had a picture of the rainbow from the scan, it was a mess. It was so bad that our school's wifi access points were flooding themselves..
Unread 12-12-2014, 01:46
Pumped
AKA: Ryan
Rookie Year: 2012
Bad enough to where everyone on wifi experienced slow browser loading? I'm pretty sure this is the problem, since it explains why our wifi (phones, tablets and robots) is so slow compared to the actual network speed.
(2015-?): 973
(2012-2015): 955
Unread 12-12-2014, 11:15
Software Architect
Check with the people who run the school's networking. It's possible that there is something enabled that actively tries to shut down what it detects as "rogue" access points.
You might try setting up the robot's D-Link as a bridge, and connect both it and the Driver Station computer to the school network. Depending on what security is set up, and whether or not you end up on the same school AP, it should work.
