Go to Post No. This is CD, take the threads and their topics seriously. - pwnageNick [more]
Unread 12-12-2014, 18:10
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
A different water game, this one on my boat
I have a boat.
It has an engine that produces water at 170 degrees F after about 20 mins of use. The water temp starts at 50F and increases in a linear fashion until 170 and then levels off. The cold / raw sea water system kicks in and keeps the temp at 170 F
I have two water tanks, each holds 11 gallons of water
They have a 3/4 copper pipe in them, 6 feet long in a coil. The coolant water cycles through the tubing to heat the fresh water in the tank.
Code:
engine --> Tank 1 ----> Tank 2 --->  return to engine
If I start with 50 degrees F water in both tanks how long until the water reaches 120 degrees? I understand at some point both tanks will be at 170 degrees F, I'm interested in the 120 F mark.
If I replaced these two tanks by one tank that held 20 gallons and routed the water twice through the tank:
Code:
engine --> Tank Upper Loop ---> Tank Lower Loop --> engine return
How long would it take to get this tank up to 120 F?
(disclaimer: I have the boat, I've done the real world testing, so I know the answer to question 1 (two tanks). )
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
