Go to Post I learned about how FIRST really is about so much more than a robot competition, it is about team building and the individual. - Adel Hodiwala [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 13-12-2014, 19:55
Oblarg Oblarg is offline
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
Flush-mounting rivnuts
Is there a "proper" way to flush-mount a rivet nut? So far I've just been lightly countersinking the hole with a larger drill-bit before setting the rivnut, which seems to work OK, but it seems a bit crude and I was wondering if there's a better way to do it.
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
Unread 13-12-2014, 20:24
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Rookie Year: 1996
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Flush-mounting rivnuts
You could counterbore with an end mill. There is a style rivet nut that is knurled to "lock" it into the mounting hole, which make them a lot less prone to spin, making it difficult to remove.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 13-12-2014, 22:11
BenDSterling's Avatar
BenDSterling BenDSterling is offline
Alumni, Mentor, Volunteer
FRC #6325 (Reset Robotics)
Team Role: Coach
Rookie Year: 2011
BenDSterling will become famous soon enough
Normally, you wouldn't flush mount a rivet, they are designed to stick out.
But, the proper way to flush mount a rivet would be to drill a hole about 1/16" larger than the head of the rivet so that the head of the rivet would sit down in the hole. Make sure that the material you are riveting is thick enough so that this does not affect the strength of the material or the joint.
Also make sure you are using the correct type of rivet. Use flat-head rivets or countersunk rivets instead of normal rivets.
Lead Mentor: FRC Team Reset Robotics (#6325)
Mentor: FTC Teams #9686 & #10396
Head of AV for Georgia FIRST Robotics
FTC South Super Regional planning committee member
Unread 13-12-2014, 22:15
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Get the right type of rivet nut, Countersunk Rivet Nuts. Then apply countersink as you would for any other countersunk fastener.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 14-12-2014, 00:05
AKA: Eli Barnett
I did get these (well, to be specific, these, but the ones you linked look very similar), though as far as I can tell they're not really "countersunk" in any appreciable way, they just have very small heads.
Unread 14-12-2014, 08:21
Zstack836's Avatar
Zstack836 Zstack836 is offline
Mentor
AKA: Zach Stack
Zstack836 will become famous soon enough
Send a message via AIM to Zstack836
Depending on the brand, the countersunk will look slightly different.
The RoboBees
Unread 14-12-2014, 09:37
AKA: Eli Barnett
The only ones I can find that appear to actually have what I'd call a "countersunk head" (i.e. a 90-degree conical shape) are metric thread. The ones advertised as "countersunk head" in standard appear to be identical to the "k-series" rivet nuts.
Unread 14-12-2014, 12:16
Zstack836's Avatar
Mentor
AKA: Zach Stack
I know they exist since we have used them in the past, as for where we got them from.. that I am not sure about.
An internet search provided this document:
http://www.rivnut.com/pdf/rivnut/riv...round-body.pdf
Looks like you can get them anywhere from 6-32 all the way up to 1/2-13. Would have to request a quote if going through this manufacturer. I looked around to try and see if there was anywhere else that could provide these but I found what you did, only metric. This is the only site that I saw provided standard hardware.
The RoboBees
Unread 14-12-2014, 12:52
AKA: Eli Barnett
Thanks a lot for the link, I'll call them up tomorrow.
