Go to Post Only a few more days till i get to see her again! This is sad you would think I was talking about a chick... no wonder my gf gets jealous. XD - sportzkrazzy [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 17-12-2014, 12:57
crollison crollison is offline
AKA: Chris Rollison
FRC #4809 (Black Knight Robotics)
Team Role: Coach
crollison is an unknown quantity at this point
First Choice Video Card
Anybody know what type and where to purchase the power cords needed for the Video Cards that came out in First Choice? Doing a little reading says it needs power to two places. Thanks.
Unread 17-12-2014, 13:03
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: First Choice Video Card
We built a computer and hooked it up yesterday with the new card. Besides putting it into the correct slot, we didn't add any power cables and it seems to be working just fine!
Just make sure you have the correct driver installed for it.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 17-12-2014, 13:05
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Rookie Year: 2010
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
You need one standard 6 pin PCIe power cable. Most modern computer power supplies should have at least one.
This could burn out you motherboard under heavy load. The 6 pin PCIe power plug is on the back of the card.
See this product page for specs, and this PDF for the power guidlines.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 17-12-2014, 13:29
pribusin's Avatar
pribusin pribusin is offline
Uber Alien
AKA: Mike 1
FRC #4004 (M.A.R.S. Rovers)
Team Role: Coach
pribusin has a spectacular aura aboutpribusin has a spectacular aura aboutpribusin has a spectacular aura about
It may work under light computational loads and seem fine during idle but once you start using graphics intensive programs or do a quad monitor setup, your system may crash and/or suffer electrical damage. We had that happen to one of our quad-monitor systems with dual graphics cards once. It worked fine initially when we tested it but even using labview over quad screens would make it crash after a short time.
Unread 17-12-2014, 14:04
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
Team Role: Leadership
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
I'm not sure what kind of packaging that card came with, but virtually every graphics card I've ever bought that has an additional power connector on it has come with a big sticker on it saying something to the effect of "Do not under any circumstances use this card without the additional power connector attached and powered by an adequately rated power supply".
Those connections are NOT meant to be optional.
Plus the adapters to connect them are super cheap if one wasn't included. Wouldn't you rather spend $5, instead of $500 replacing a graphics card?
Unread 17-12-2014, 16:14
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
Any modern power supply should include the necessary cables. Trying to find and buy them yourselves is probably a bad idea. If your power supply doesn't already have what you need, you probably need a new power supply.
Does anyone else remember when TBA signatures actually worked?
Unread 17-12-2014, 16:18
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Yup. Unless you have a modular power supply, getting a cable off the internet and hacking it on is going to void your PSU warranty and probably cause you problems.
Side thing: A lot of people skimp on the PSU when building a PC but that's a really terrible idea-- a bad PSU will cause you nothing but issues down the road-- and possibly the rest of the components in your build. Get a nice, quality PSU and you'll never have to worry about it.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 17-12-2014, 16:51
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
The card we received has no auxiliary power input, the only additional connector is the SLI bridge. You've also linked the wrong card. The K model is a newer generation than the one on FIRST choice.
2014-2015: FRC 865 Warp7 Team Captain
2016: FRC 865 Mentor
Unread 17-12-2014, 17:06
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
Rookie Year: 2010
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
Are you sure? It's listed as the K4000 on the FIRST Choice website and both have identical specs. They both list the power draw as 80W.
Edit: Also, on the product page for the card linked by cadandcookies above, it says that the package contents include an auxiliary power cord and I don't see any reason why AndyMark/FIRST would remove it from the package and ship only the card itself. If that actually is the case, you should probably buy the cord by itself.
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
Unread 17-12-2014, 17:09
mman1506's Avatar
no team (WARP7)
Rookie Year: 2012
Sorry my mistake it is a K series. Still the card we received appears to be a different variant of K4000 card (maybe a OEM version) than even the one of FIRST choice and does not have an auxiliary hook up.
Unread 17-12-2014, 17:34
Chris_Ely's Avatar
AKA: luckof13
Rookie Year: 2010
As far as I know, all K4000s have a 6 pin power plug on the back. See the attached picture.
Name:	K4000 Power Plug.jpg
Unread 17-12-2014, 17:37
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
Rookie Year: 2012
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
This is a different model than the FIRST Choice one. In that one, only part of the circuit board is covered by the black box.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
That's not what came in FIRST Choice.
These are what came;
http://www.ebay.com/itm/NVIDIA-Quadr...em35e1f6 8dd7
http://www.ebay.com/itm/NVIDIA-Quadr...em2c9323 7098
http://www.ebay.com/itm/NVIDIA-Quadr...em27f3ab 6b7e
Unread 17-12-2014, 17:46
Chris_Ely's Avatar
AKA: luckof13
Rookie Year: 2010
Sorry, I did not realize that there was this model. Every image that I have found was of the variant that I linked to, including FIRST Choice and nVidia's product page.
  #15   Spotlight this post!
Unread 17-12-2014, 17:47
AdamHeard's Avatar
Lead Mentor
Oh that's funny, I didn't realize the AM page had the wrong pic.
