Go to Post FIRST robotics: Not just for nerds. - Koko Ed [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 17-12-2014, 22:25
atucker4072's Avatar
atucker4072 atucker4072 is offline
Andrew Tucker
AKA: Andrew Tucker
FTC #4968 (Rapid Robotics)
Rookie Year: 2011
atucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura about
[FTC]: Drawer slides as a linear lift
The current team that I am mentoring is using the Tetrix rack and pinion kit for linear motion applications. And there are problems with it like the small plastic guides. If you have them to tight the system will not slide easily and if they are loose they won't stay in place. So they want to give drawer slides or similar slides as an option. After looking at some examples I'm not seeing how they are being lifted. We understand the rigging of a cascading elevator but are not sure how to set it up with a drawer slide. Do you use pulleys to hold the wires? Or what?
