Thread Tools |
Rating:
Display Modes |
Re: Anderson Power Pole for motors
To apply XT60s properly, you need to also use heat shrink, or electrical tape, to cover the back side of the terminals. That is not required with the Anderson connectors.
GO TEAMS! |
Our team purchased a shrink tubbing label printer for this year. Hopefully all wires will now be clearly marked to simplify tracing and reduce the chance of a connector being plugged into the wrong connector.
How many connectors do you typically have on a robot? I believe we generally only have 1 per motor. Steve |
What is your source for this?
Note it does not take into affect the insulation type and the CIM uses high temp insulation since it goes inside the motor where it is subject to heating caused by the motor. It is also a very short section of wire. That is why we are required to use 12ga with a CIM if we want it to be connected to a 40a breaker even if the wire that exits the CIM is 14ga. |
We used them last year along with a detachable drive rail design that made any drive maintenance an absolute breeze. Highly recommend them!
One more tip. This is the first year I have purchased this pick tool for removing wires/terminals from housings.
For $12 I think it is a good addition to the toolbox. Yes, you can live without it but it works pretty well. Also, I recommended using cable ties (aka tie wraps) to hold connections together. Other teams swear by these BLOK LOK Clamps. I used them one year but at $1.39 each it seemed like cable ties were a better solution. What do others think? Also, I see there is another option I have never tried. These Retention Clips These are only $0.49 each. Still not as cheap as a cable tie, but more reasonable than the BLOK LOK. has anyone had success using these? Do Tell... Dr. Joe J. |
#10
Unrelated to the clips, Powerwerx sells these housings, which we used throughout the season. Those housings are bonded and as such have built in polarity protection. We may have had one of these seperate, but it was not on the robot and I believe it went through a serious trauma (hit with a hammer). |
#11
I've always used a cable tie, zip tie or however many more names they go by.
But 49 cents isn't bad at all. |
