Go to Post Ah, to be a teenager and know everything again. - Alan Anderson [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 21-12-2014, 11:14
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Rookie Year: 2012
Gregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond repute
Re: pic: Low Profile Gearbox Front View
Originally Posted by JesseK View Post
Under what conditions would one "lose a CIM"? In 10 seasons I have yet to experience a bad CIM or see one in person.
I have, just once. It was a brand new CIM in 2012. We weren't able to climb the bridge straight one match, so right after the match we felt all four CIMs, three were the standard moderately warm to touch, one was cold as if it hadn't been running (which it hadn't, we checked after removal).
While rare, it can happen so it's not a bad idea to design for CIM removal.
What are nationals? Sounds like a fun American party, can we Canadians come?
“For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.” -Jean Dubuffet
"Insanity is doing the same thing over and over again and expecting different results." -Albert Einstein
FLL 2011-2015 Glen Ames Robotics-Student, Mentor
FRC 2012-2013 Team 907-Scouting Lead, Strategy Lead, Human Player, Driver
FRC 2014-2015 Team 1310-Mechanical, Electrical, Drive Captain
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 21-12-2014, 16:44
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
I have right now no less than four cims sitting my garage. I took them home because they were burning up and were no longer used on the team.
Some grease on the insides brought them back to life, but it is possible if they heat up too much.
Unread 20-12-2014, 21:09
Cash4587's Avatar
Cash4587 Cash4587 is offline
Mentor
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Team Role: Coach
Rookie Year: 2013
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Originally Posted by Andrew Lawrence View Post
How is this mounted to tubing? It looks like it's only using the bearing block bolts to hold the gearbox on.
Also, slight tidbit - the ability to use multiple pinion sizes is a design and feature of WCP gearboxes, not the VEX ones. The DS and SS are made by WCP. VEX and WCP are resellers of each other's products. Just clearing that up so that credit is given where credit is due.
I would assume since this gearbox is modeled like the WCP DS, that the bolts on the bottom part of the GB would go through the tube and bolt to it.
Unread 21-12-2014, 01:09
JorgeReyes JorgeReyes is offline
Team Captain
FRC #2002 (Tualatin Robotics)
JorgeReyes is an unknown quantity at this point
Apart from the the bearing block, the two bottom bolts through the tube and bolt onto it, just like cash4587 said.
You are correct it is the DS and SS gearboxes that make the adjustable cim mounts but I am so used to using components from both that I tend to get them mixed up a lot.
Unread 20-12-2014, 21:21
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Nice design. I'm a little worried about how the chains or belts will make it out of the gearbox and to other wheels. It looks like they would go right into the lower standoff tubes.
Unread 21-12-2014, 11:56
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
We managed to damage all 6 CIMs in our drivetrain at Waterloo last year. We were having issues with popping breakers, inconsistent performance and the CIMs getting very hot very quickly. When we removed each CIM from the gearbox we found their no load current was 7-10 amps versus 2-3 amps a stock CIM would have. Replacing all our CIMs fixed our issues.
2014-2015: FRC 865 Warp7 Team Captain
2016: FRC 865 Mentor
2017: Free Agent Mentor, Inspector
