| Thread Tools |
Rating:
Display Modes |
Best Practices for Not Crushing Thin-Wall Tubing
As anyone who has had students put bolts through aluminum tubing knows, it's really easy to crush the tube by overtightening. For especially thin-walled tube (1/16'' or thinner), it can be difficult to not do it.
I was wondering what teams consider a "best practice" for avoiding this. I've used both washers and wood inserts - the former doesn't work quite as well as the latter, but is easier. Last edited by Oblarg : 12-21-2014 at 11:22 AM. |
Re: Best Practices for Not Crushing Thin-Wall Tubing
Unless you have to, don't through-bolt, place your nuts on the inside of the tube, so that you're only putting load on one side of the tube. For this reason, rivets are my preferred fastener for working with this type of material, since they do this automatically, and can do so blind, right in the center of a tube.
Wood or plastic inserts also work well for the ends of tubes. Plastic has the advantage of being tappable. If this can't be done, use versa block style construction, clamping onto the tube, allowing the strongest part, the edges, to support your parts. This can be done even without advanced machining. Use a few small screws with through holes to locate your part on the tube, and then bigger screws on the outside to provide the real clamping force. Short of this, make sure that the parts on both sides of the tube are supported by the whole tube, not just the middle. Again, the edges, where you gain the full support of the sides parallel to your fastener, are the strongest parts. Make sure your part takes up the whole height of the tube when possible. A cool trick to achieve this is to make an aluminum plate the height of the tube to slip under your nuts, distributing the load. |
wood in the tube, I have been doing this for years. Typically during the field construction, I will rip down some .875x.875 square dowels from 2x4 for this purpose. The wood adds less weight than going to thicker wall tubing but provides plenty of crush support.
We actually did this last year with some fiberglass square profiles also, to provide a better surface for mounting a bushing all the way through the tube. |
Depending on the application, rivet nuts or rivets are an option too. There are many situations where you don't need to go all the way through the tubing.
In addition to proper tightening. We find it easiest to just cut out a small piece of PVC to length and run the bolt right through it. Works like a charm.
2. Ribbed ones are less likely to rotate 3. Bit size is important |
I've got 2. and 3. covered. Tightening, I'm still unsure about. I've been following the "stroke length = min rivnut grip width + max rivnut grip width - material thickness" formula and hoping that works, since I can't really "feel" when the rivnut has tightened fully and I don't want to damage the threads.
#10
Using washers on both sides work well for us when we through bolt also stuffing the tubing with wood or plastic.
#11
sometimes a little crush isn't such a bad thing
we often tie off the ends of our "469 signature" 1/4" tubing by heating with a torch and then crushing flat in the jaws of a vise ... at the right angle, of course! then we drill a hole through that and rivet it to whatever. works pretty nicely! |
#12
To answer the OP's question, there are a few ways to do this.
You can bypass this problem entirely with rivets or rivet nuts, as previously mentioned. If you are installing bolts the OTHER way (as in Bolt Head -> Tubing -> Thing You Are Screwing The Bolt Into), you can drill a tool clearance hole through one side (3/8 works well for a #10 screw). The other method that Greg touched on is to insert some kind of material inside the tube. Wood is a great choice as it is rigid and light - I am honestly surprised more teams don't use wood inserts to increase tube strength for very little weight. If you are looking for something you can tap, a smaller plastic insert (delrin) can work pretty well depending on how much load those threads will see. Finally, depending on how much tube access you have, if its easy, just slide your favorite kind of hollow tubing in the hole and run the bolt through its center. If you can't avoid it, washers will help slow down the crushing process which helps I guess. Don't use .04 wall tube without support in this manner! Quote:
A properly installed rivet nut can take a lot of load. We lifted our robot via four eye bolts screwed into four rivet nuts in the chassis. This is something I was very nervous about until we actually did it and tested it, but rivet nuts can do the job! |
#13
Last year we predicted some crushing issues. We decided to use some delrin blocks milled to fit tightly inside of a length of 2x1. They had a hole in the center to allow some wire rope to fit through, but it could be used for bolts as well. Took about 30 minutes to make a set of them.
This method worked great for us. Our 2x1 did not crush where we had the delrin. EDIT: We used washers at one point as well, but they actually ended up warping. |
#14
We love this since there is only one step. Part the tube to length.
#15
Just ensure you go against the grain or the block can split. I've even threaded the wood, when needed. |
