Go to Post The code won't compile if you violate the rules of the programming language...but English is more robust, it seems to work pretty well no matter how we engineering nerds mangle it! - MrForbes [more]
Unread 21-12-2014, 13:24
FRC Team CC FRC Team CC is offline
FRC #6560 (Charging Champions)
Rookie Year: 2012
FRC Team CC is an unknown quantity at this point
Arrow [FTC]: FTC Encoder Program with Distance
Hello,
We are trying to program our Autonomous portion using distance with
TETRIX DC Motor encoders. The following is our program:
Code:
#pragma config(Hubs,  S1, HTMotor,  HTMotor,  HTServo,  HTMotor)
#pragma config(Motor,  mtr_S1_C1_2,     leftBottomDrive, tmotorTetrix, openLoop, encoder)
#pragma config(Motor,  mtr_S1_C4_1,     rightBottomDrive, tmotorTetrix, openLoop, reversed, encoder)
//*!!Code automatically generated by 'ROBOTC' configuration wizard               !!*//
task main()
	float diameterOfWheel = 3.96;//set the diameter of wheel to 3.96 inches
	float circumfirence = diameterOfWheel*PI;
	int distanceToGo = 12;//we want the robot to go one foot, or 12 inches
	float rotations = distanceToGo/circumfirence;
	int degreesToTurn = rotations*360;
	int encoderCounts = degreesToTurn*4;//encoder counts are in quarter degrees, so 4 encoder counts = 1 degree
	nMotorEncoder[leftBottomDrive] = 0;//motors do not run
	nMotorEncoder[rightBottomDrive] = 0;
	nMotorEncoderTarget[leftBottomDrive] = encoderCounts;//tell motors to go a foot
	nMotorEncoderTarget[rightBottomDrive] = encoderCounts;
	motor[leftBottomDrive] = 50;//go at power 50
	motor[rightBottomDrive] = 50;
	while(nMotorRunState[leftBottomDrive] != runStateIdle)
	motor[leftBottomDrive] = 0;//turn motors off
	motor[rightBottomDrive] = 0;
When testing the program, the motors drove unlimited instead of stopping after one foot.
Regards,
The Charging Champions
