Good Screw Sizes fo General Use
Hello all,
I have to give in a list of consumables to one of our local sponsors as he would like to donate all of our screws, bolts, nuts, and wire. What general sizes of screws and bolts are best to stock up on for the upcoming season? Thanks! |
Re: Good Screw Sizes fo General Use
We heavily standardize on #10-32, and love it.
Vex has sort of standardized on #8-32, but has some #10 and 1/4 mixed in. |
For nuts we like to use KEPS and Nyloc variety. KEPS have a built in star washer and are cheaper than Nyloc, but Nyloc gets the job done without the need for excessive torque or loctite
What we stock:
8-32 10-32 1/4-20 Socket head cap screws from 1/2" length up to 3" or so. Also lots of nylon insert lock nuts and flat washers. Black oxide preferred over other materials. |
We use mainly #10-32 (Black oxide) and some #1/4-20, but the #1/4-20's are mainly used for high stress/abuse parts. For nuts we mainly use nylon lock nuts and standard hex nuts.
5/32" rivets; #8-32, #10-32, and 1/4-20 screws.
The 5/32" rivets are most common individual hardware, followed by #8-32 and #10-32 screws for general purpose mechanisms. 1/4-20 screws are pretty much exclusively used for tube axles (dead axle shaft+standoff combo) or high-loading parts. I try to avoid #10-24 and #6-32 like the plague as these are the most commonly broken tap sizes due to their ratio of pitch to shank diameter (look at a #6-32 tap wrong and it breaks), and #10-32 is WAY more common for COTS stuff. |
We use #10-32 and 1/4''-20 bolts (socket head preferable, hex head for 1/4''-20 also OK, phillips head is a no-no since they're basically designed to strip) for structural bolts. Trying to move more towards the former as the latter really is overkill for most stuff in FRC. Nylock nuts are standard.
After years of frustration, mismatched nuts, and accidental crossthreading, we will no longer purchase #10-24 on either team I mentor. |
Make sure you get the nylon/teflon nuts that self-lock (Nylock Nuts) so that you don;t have to loctite screws. They come in thick and thin profiles for different applications as well. They are so easy to use and never have I seen one vibrate loose if properly tightened.
We use mostly 10-32 on our robot. 1/4"-20 is good for some high-load applications. Dead axle screws.
Nylock nuts are really nice, but get some thin ones too. They come in heights of 9/32" normally and 1/8" (4/32") for the thin ones IIRC for 10-32 screws. We use a lot of 1/8" rivets. Vex uses 5/32" for the versachassis. 3/16" rivets are interchangeable with 10-32 screws in terms of hole size. |
#10
We use almost exclusively #10-32 hardware and 3/16 rivets so we only have to drill one hole everywhere. #8-32 screws and 5/32nd rivets are used to interface with weird Vex stuff sometimes.
Socket head cap screws basically every time. |
#11
Whatever the job requires. #10-24 is generally the first bolt we reach for (if something can't be riveted). We'll use 10-32 if we need more thread engagement, but they just take to long to screw in and out. Our one general rule is absolutely no metric unless we're forced to.
#12
The only real advantages that find thread have are the the bolt itself is slightly stronger and that it is slightly less prone to loosening from vibration. http://www.bestbolt.com/white_papers/white_paper_08.pdf |
#13
What's the advantage of using socket head over button head?
#15
Socket head typically has a deeper hex, so it's harder to strip out.
I like 10-32's over 10-24's because it's harder to break the 10-32 tap. As a rule of thumb, I try to get more than 6 threads of engagement in a tapped hole in aluminum. With a 10-32, that works out to 6/32 = 0.1875", but a 10-24 requires 6/24 = 0.250". Once you've used both for a while, it becomes easy to identify the different threads on bolts, and you can check to see if your nut threads easily on a known bolt. We've used 1/4-20's as axles for flywheel shooters and pivots for catapult shooters, as well as gearbox mounts. 3/8-16 or 3/8-24 is our favorite for dead axles. |
