Go to Post Not only does Dave like to post hints about the the new game...but now he's starting to post hints about the activities of the Mars rover. Does it ever stop?! - Alexa Stott [more]
Unread 21-12-2014, 23:06
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
Rookie Year: 2010
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
I2C working on RoboRIO
Today's effort was trying to get the I2C working on the RoboRIO. Evidently, the on-board I2C port is /dev/i2c-2 (that's the 3rd port of 3). We wanted to get a generic example of I2C code that could be extended to use any of the dozens of I2C sensors available from places like Sparkfun.
We first got a Linux only program running to prove the port was working at all. Then we ported the application to WPILib. The device was a Sparkfun ADXL345 3-axis accelerometer. Anyone interested in the code is welcome to a copy of both the Linux version and the WPILib version.
Drop by https://www.facebook.com/FRC2015ControlsBeta for a look at the hook up.
Unread 31-12-2014, 16:57
DavidBlain DavidBlain is offline
FRC #0839
DavidBlain is an unknown quantity at this point
Re: I2C working on RoboRIO
We would be interested in the code. do you have a link?
Unread 01-01-2015, 19:29
Software Mentor
AKA: Mike Anderson
Rookie Year: 2010
Yes, here is the link to a copy on my dropbox:
https://dl.dropboxusercontent.com/u/...7/ADXL-I2C.zip
HTH
Unread 10-01-2015, 14:13
mannybjh's Avatar
mannybjh mannybjh is offline
AKA: Ben Hogan
FRC #0020 (Team 20)
Rookie Year: 2014
mannybjh is an unknown quantity at this point
Did you experience any issues with this? Trying to get info on it, not helping. Also, how did you find the addresses for it all. Like knowing to send to port 16 ect.
Unread 10-01-2015, 14:31
Software Mentor
AKA: Mike Anderson
Rookie Year: 2010
I'm sorry, I don't understand what you're asking here. The code is available from the link listed earlier in this thread.
You can see a picture of how it was connected at https://www.facebook.com/FRC2015ControlsBeta . Note that this is the Sparkfun ADXL345 board -- not the one found in previous KoP deliveries! For the KoP sensor, use the provided WPILib classes. Our I2C example code was just a way to demonstrate I2C on the RoboRIO from start to finish.
HTH
Unread 05-02-2016, 16:27
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
This year, the ADXL345_I2C class was updated to take alternate address, like the Sparkfun board uses. Is there another reason the WPILib classes don't work?
Unread 05-02-2016, 17:13
Software Mentor
AKA: Mike Anderson
Rookie Year: 2010
There shouldn't be. But, I haven't revisited this with the 2016 WPILib as of yet. If it works out of the box, please post that so others will benefit as well.
Thanks,
MikeA
Unread 06-04-2015, 20:53
Software Mentor
AKA: Mike Anderson
Rookie Year: 2010
HTH
Here is a copy for posterity.
HTH,
Mike
Unread 04-02-2016, 16:59
The Doctor's Avatar
The Doctor The Doctor is offline
Robotics is life
AKA: Hackson
FRC #3216 (MR. T)
Rookie Year: 2013
The Doctor is on a distinguished road
HTH
Link is broken.
Robots + Python + pentesting == me;
Blog ~ GitHub ~ Keybase
If you have a pressing issue to discuss with me, kik me at slush.puddles since I don't check CD very often.
Unread 04-02-2016, 18:31
Software Mentor
AKA: Mike Anderson
Rookie Year: 2010
You can pick it up from the message just above it where I attached the zip file to the message.
HTH,
Mike
