Thread Tools |
Rating:
Display Modes |
Re: 2015 HINT DISCUSSION
In 2009 the regolith was white and was pretty reflective. In the end of the hint you can see the reflection of the floor and its clearly not white.(This is assuming he was standing on the playing field).
2014 was nice in that regard. Fewer moving pieces led to short field reset times, so the extra 20 seconds of match time didn't make the events longer. |
I would like to see a triangular field with each side playing host to both a Red and Blue driver's station. That would mix things up a bit.
Or with each side having an alliance (three alliances) or having one not per side with three bots totally (doing away with alliances).
Re: Discuss the Game Hint
Should we expect bigger alliances and/or robots?
I think smaller alliances but three (triangle)
I will bet with very good odds that the size/number of alliances is not changing.
two different gamepieces....
#10
So, "Change is coming" prefaced by a list of games, their major rules changes to basic elements of how the games work, most of which occurred in odd years. So the field is changing shape, composition, or dimensions, or something else.
I don't see how this is substantially more information than when Frank mentioned earlier in the year to take nothing for granted, that anything might change. If the recycling bin is relevant, it might be saying "We're bringing something old back, that we've long-since changed". Perhaps the 3v3 model is changing? That could relate to the way Einstein is being run, since the footage seemed to be all from Einstein. |
#11
I added the intervals and got 19. The number 19 has been retired the most in the NHL
#12
smaller Hexagonal or odd-shaped field, no alliances, maybe 1 v 1 or FFA with multiple and it'll be an arm game with elements to be picked up and placed.
The deletion of the 1999 game (link below) and replacement of it with the 1997 game is definitely significant (recycling 1997). 1999 was the first year with alliances as mentioned in the video but it was also the first year with a regular rectangular shaped field (disregarding 1992 which was a raised square sandbox) and every field since has been a regular rectangular shape. I believe that alliances and the rectangular shaped field will both be done away with for the coming game. Also when the guy opens the game manual he flips to the first pages which described the field in the 2014 game manual. Finally, it will be similar but a variation on the 1997 game because the 1997 game is the one being recycled so it will be some sort of arm game. 1999 Game: https://www.youtube.com/watch?v=Q0CDop_IwW8 Link to FRC 2015 Game Hint: https://www.youtube.com/watch?v=aAETANAiLw0 |
#13
Frank posted a rule on the FRC blog:
R13: Software and Mechanical/Electrical designs created before kickoff are only permitted if the source files (conplete information sufficient to produce the design) are available publically prior to Kickoff. Sounds like a hint about recycled designs? 😂 |
#15
