Thread Tools |
Rating:
Display Modes |
Re: Got Gyro drift? Try Sensor Fusion !
Hello,
I am using the National instrument NI USB-8451. Do you think your programm can work with this device? When I open the programm in Labview, it looks for library " ROCK ROBOTICS" but it doesn't find it. Do you know where I could download this library? ( then i will maybe not have these "?"). I don't understand what is "FIRST FRC version of LabVIEW ". ( I am using LABVIEW 2014 STUDENT EDITION). What is FIRST software/hardware? Best regards |
Unfortunately, tetris, this is a forum for a specific set of hardware and software only available to FIRST robotics competition teams (google it to find out). We probably won't be able to help with using other NI hardware and software.
I suggest posting to one of the forums that NI sponsors. -Steve |
HI,
where can I download lobrary "ROCK ROBOTICS"? in order not to have these "?" Best regards |
The Rock Robotics library is designed to work with the hardware used by FIRST Robotics Competition teams, and the special FPGA image that goes along with it. If you don't have a RoboRIO or FRC-cRIO system, you won't be able to use them. And even if you do have that hardware, you will need the special Driver Station program running on a network-connected Windows laptop in order to enable the hardware outputs.
While some of us here are able to give general advice, you're not likely to get the specific help you're looking for in this forum. |
