Go to Post "I'm not going to tell you all that you all are winners. At this point you are smart enough to know whether you are or you aren't." -Woodie Flowers - Barry Bonzack [more]
Unread 01-01-2015, 21:48
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
Frog Force 503 Code Release
We've made a few programs and would like to release the code for them. None of them are actually for use on the robot, but I think the spirit of R13 still applies.
  • GameAnalyzer.zip contains code for analyzing game strategy with examples from 2014. EDIT: Now also includes a basic script interpreter to simplify making games. The first version also had an error in it with how it chose possible strategies and would miss certain strategies. This version fixes that, but makes the deterministic calculations take much longer.
  • DataAnalyzer.zip downloads data from TheBlueAlliance and creates Fantasy FIRST pick lists out of it. It also contains a work in progress match predictor.
  • opencv.zip contains a few example Java programs using the Java bindings of OpenCV. I had great difficulty finding examples for Java, and these are to illustrate pretty basic things like color thresholding and corner detection. There's also "FrogyVision", a Java Chezy Vsion clone.
There will be another big release coming from us in a few days, but it isn't completely done yet.
Unread 02-01-2015, 23:30
orangelight's Avatar
orangelight orangelight is offline
AKA: Alex
FRC #0548 (Robostangs)
Rookie Year: 2014
orangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to behold
Re: Frog Force 503 Code Release
Were you able to pull images from a camera on the robot to the driver station?
Unread 03-01-2015, 06:29
FF TSL: Frog Farce
Haven't quite gotten that worked out yet, but I think that the OpenCV video capture object lets you specify a web stream.
