Thread Tools |
Rating:
Display Modes |
Re: ANNOUNCING: navX MXP Robotics Navigation Sensor
Lead time is 5 weeks. We will be deciding soon when to send out the next order, based on initial sales velocity.
Looks like you had that initial sales velocity. To those on CD, what is a good alternative to this IMU? If any.
http://www.andymark.com/product-p/am-3060.htm |
I'm trying to get the navX set up for some basic tests.
I plugged it into the roborio, then opened up the roborio example labview project. I replaced the ip to roboRIO-2067.local and deployed the code (which succeeds), but I can't get any readings out of it.. It just throws a bunch of errors, starting with the serial block. Am I doing something wrong here? |
Are you using the Nav6 project? If so, you need to add the serial port parameter to the serial open to use the MXP serial port, as it defaults to the onboard RS232 serial port. I believe there's a better library coming soon.
A good LabView library just got better.
Last year, the original LabView nav6 Serial Port-based libraries were created for the FIRST community by Joe Ross from Team 330 (Beachbots). Now, thanks to the efforts of James Parks from Team 900 (Zebracorns), these libraries have been enhanced to add SPI support and expose some navX MXP and RoboRio-specific features. Following the open-source tradition, these enhancements have generously been made available for all to use. The latest build of this LabView library, which now supports both Serial and SPI interfaces, is now available at https://code.google.com/p/navx. The SPI Library features lower-latency communication and also lower RoboRio CPU bandwidth utilization. At the default update rate (60Hz), the Serial libraries were measured at 17% CPU utilization, whereas the SPI library was measured at 11% CPU utilization. Note that the navX MXP also supports I2C communication, and an I2C version of the LabView library is planned; we'll send out an update on this thread when this work is completed. Thanks to the ChiefDelphi community for continuing to support this open-source project. |
I missed the restock on AndyMark last night, I thought they were going to restock on Friday but I guess they must have got them earlier. Any word on when they will restock?
#10
There still are some remaining nav6 units on sale at www.kauailabs.com/store. While I realize this isn't an ideal situation, the navx MXP is backwards compatible with the nav6 serial protocols, so should you choose to use the nav6 now, an eventual upgrade to the navX MXP should be pretty straightforward. |
#11
So for the NavX, would it be a problem to both hook up to the USB port, and hook up to the MXP port?. Where would the processor draw power from, and would this cause any issues with anything else?
#12
I convinced my team to get one to play with (when they are back in stock), but now we have a need for more DIO ports, so ...
All I can find on the navX is the data sheet. Is there a pin-out diagram? The ports are labeled well. I'm sure there is a standard, but I like to know for sure, which pin is for power (usually the middle), signal, and ground. |
#13
