Go to Post Next year they should make Roombas the game piece. They're not very effective at vacuuming the rug that's for sure. - Koko Ed [more]
Thread Tools Rating: Thread Rating: 29 votes, 5.00 average. Display Modes
Unread 12-23-2015, 02:08 PM
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
Rookie Year: 2010
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Re: ANNOUNCING: navX MXP Robotics Navigation Sensor
Thanks! We're looking forward to seeing the updates!
Unread 12-23-2015, 02:11 PM
Software Mentor
AKA: Mike Anderson
Rookie Year: 2010
If you need someone to help test the updates with the 2016 Beta libraries, we'd be happy to help.
Mike A.
FRC #116
Unread 12-26-2015, 01:11 PM
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
Mike A.
FRC #116
Hi Mike,
Beta versions of the navX-MXP C++/Java Libraries which are compatible the 2016 Beta WPI Libraries (C++/Java) are now available for testing. Anyone interested can PM me for details on getting a copy of the beta libraries.
The functional changes are:
- C++/Java: navX-MXP Libraries compiled w/latest 2016 WPI FRC beta libraries.
- C++/Java: I2C transfer sizes, previously limited to 7 bytes/transfer in the WPI Library, have been increased. The navX-MXP libraries now transfer all I2C data in a single bus read transaction, increasing performance.
Not yet changed:
- Java: to link w/the navX-MXP Java library, the WPI Library's build.properties file must be edited, as described in these directions. This additional step will be removed before the final release of the navX-MXP C++/Java Libraries for 2016.
Unread 12-26-2015, 06:30 PM
Jonathan L. Jonathan L. is offline
FRC #1094
Jonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the rough
Unfortunately, the examples fail to build in the 2016 control system betas. The compiler complains about:
"invalid new expression of abstract class type 'AHRS'" and dies a horrible death.
Just to make things clear: Is this just a problem with C++/Java? Is the 2016 beta navX LabVIEW code working? If not will it be updated by kickoff? Thank you!
Unread 12-26-2015, 09:05 PM
Software Mentor
AKA: Scott Libert
Yes, the previously reported compile problem when used with the 2016 FRC beta was limited to C++ and Java, and a fix for that issue is now in beta.
LabView is good to go. James Parks, the creator of the new V2 LabView NavX-MXP Library (http://www.chiefdelphi.com/forums/sh...highlight=NavX) has successfully tested the LabView library against the 2016 Beta, and indicates it works fine with the SPI, I2C and TTL UART interfaces.
The only further work remaining is to deal with an issue found when testing the USB interface against the FRC 2016 beta image/library.
So give it a go and let us know how it goes. The SPI interface is highly recommended.
Unread 12-26-2015, 09:50 PM
FRC #1094
My team is not a beta testing team, so I can't test it until build season. Anyway, we got the navX working with the 2015 FRC LabVIEW software recently. Looking forward to using it next year!
Unread 01-09-2016, 10:35 AM
Software Mentor
AKA: Scott Libert
The navX-MXP Java and C++ Libraries have been updated to work w/the new 2016 WPI Libraries. And the Zebracorns have released an updated LabView library for 2016. The latest build of all these libraries is available now.
In addition, Team Shockwave has created a C# RoboRIO Library that also features a navX-MXP Library.
And there are more examples than ever both in the examples provided with the C++, Java and LabVIEW Libraries, as well as in the recent team code releases, including those of team 2465 (Kauaibots).
And we've heard wind of a Python RoboRIO Library being developed as well - we'll let you know when more details are available on that.
KauaiLabs wishes everyone an incredible 2016 build season!
Unread 01-26-2016, 10:26 AM
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
Where is the CAD file for the MXP located? I downloaded the zip file, checked Git, but I still don't see the actual CAD file for the board itself. I am looking for the SolidWorks CAD file.
Thank you.
-T
Unread 01-26-2016, 11:52 AM
FRC #1094
Thank you.
Get the download from this page http://www.pdocs.kauailabs.com/navx-mxp/software/
The CAD files are in the zip file; no need to install everything. I don't see a Solidworks model there, but there are several SketchUp files and an STL file.
Unread 01-31-2016, 05:18 PM
schleprock's Avatar
schleprock schleprock is offline
Code Jockey
FRC #4905 (AndromedaOne)
Rookie Year: 2014
schleprock is an unknown quantity at this point
Question Re: ANNOUNCING: navX MXP Robotics Navigation Sensor
we just received a couple of the navx's and we want to use the USB port as our roborio is mounted on the side of the robot in a verticle position. i tried the DataMonitor example and i can see everything when we plug the navx into the mxp port. but i see nothing when we connect it via USB. i changed Port parameter to the AHRS constructor to SerialPort.Port.kUSB but no output to the smartdashboard. it doesn't throw an exception, so the AHRS class instance is getting constructed. there's just doesn't seem to be any communication. is the issue you refer to? and is it going to be fixed anytime soon?
thanks
Unread 03-12-2016, 09:58 AM
Acocagne Acocagne is offline
FRC #5114
Acocagne is an unknown quantity at this point
Does anyone have one of these to sell or have a supplier that has it in stock?
AndyMark and the manufacturer are both out of stock.
Thanks
Unread 03-12-2016, 10:31 AM
Software Mentor
AKA: Scott Libert
Thanks
More units should be available for sale at the KauaiLabs store by 3/22, and at AndyMark by approximately 4/3.
Unread 03-18-2016, 04:44 PM
DKolberg DKolberg is offline
Mentor Iron Giants
AKA: David Kolberg
FRC #5069 (Iron Giants)
Rookie Year: 2000
DKolberg has a spectacular aura aboutDKolberg has a spectacular aura about
I am trying to verify operation using the navX mxp by hooking up to a PC with a USB cable. When I connect the usb from the pc to the navX nothing happens, the lights on the navX blink and go green, but he PC does not see any com port nor any device loading message. when I open the configuration utility no com ports show up. How do I configure the drivers so the PC can talk to the navX?
David Kolberg
2014- Mentor Iron Giants 5069
2004-2010 Coach SBotz Team 1327
2000-2003 Mentor Team 135
2016 St. Joe District Event Winner
2009 WFA Boilermaker
2008 Driving Tomorrow's Technology
2005 Innovation in Control
2005 IRI Spirit of Indiana
Unread 03-18-2016, 05:12 PM
marshall's Avatar
marshall marshall is offline
My pants are louder than yours.
FRC #0900 (The Zebracorns)
marshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond repute
Is this a Windows system? The NavX should show up as a COM device. My best guess from your description is that the USB cable you are using doesn't support data and just does power but I could be wrong.
Scott Libert (Of NavX fame) is competing with his team this weekend so I don't think you'll get an official response until next week but I would try it with a different USB cable.
"La mejor salsa del mundo es la hambre" - Miguel de Cervantes
"The future is unwritten" - Joe Strummer
"Simplify, then add lightness" - Colin Chapman
  #15   Spotlight this post!
Unread 03-18-2016, 06:04 PM
Software Mentor
AKA: Scott Libert
When you run the navX-MXP setup the drivers are installed, at which point the board shows up as a COM port when plugged in via USB. *Be sure that you run the install as administrator otherwise depending upon your system security settings the drivers may fail to install.*
