Go to Post Ask not what FIRST can do for you but what you can do for FIRST. - Koko Ed [more]
Thread Tools Rating: Thread Rating: 29 votes, 5.00 average. Display Modes
  #76   Spotlight this post!
Unread 01-21-2015, 01:27 AM
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
Re: ANNOUNCING: navX MXP Robotics Navigation Sensor
Originally Posted by jojoguy10 View Post
Not sure about anyone else, but the NavXMXPUI program isn't working for our team. When I try to run the .bat file, it says it can't find a file.
Is there a KNOWN working version somewhere?
Thanks!
The navXMXPUI 64 bit windows version is known working, tested on Windows 7 64-bit. Please post details on the error message you are seeing. Note that Java is required to be installed, too.
  #77   Spotlight this post!
Unread 01-21-2015, 01:45 AM
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
Rookie Year: 2010
jojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of light
I'm using 64-bit Windows 8.1 (that might be the issue?)
Here is the command prompt window text
Code:
Catched FileNotFoundException: C:\Users\Joe\Desktop\navx-utilities\navXMXPUI\app
lication.windows64\lib\gluegen-rt-natives-windows-i586.jar (The system cannot fi
nd the file specified), while addNativeJarLibsImpl(classFromJavaJar class com.jo
gamp.common.os.Platform, classJarURI jar:file:/C:/Users/Joe/Desktop/navx-utiliti
es/navXMXPUI/application.windows64/lib/gluegen-rt.jar!/com/jogamp/common/os/Plat
form.class, nativeJarBaseName gluegen-rt-natives-windows-i586.jar): [ file:/C:/U
sers/Joe/Desktop/navx-utilities/navXMXPUI/application.windows64/lib/gluegen-rt.j
ar -> file:/C:/Users/Joe/Desktop/navx-utilities/navXMXPUI/application.windows64/
lib/ ] + gluegen-rt-natives-windows-i586.jar -> slim: jar:file:/C:/Users/Joe/Des
ktop/navx-utilities/navXMXPUI/application.windows64/lib/gluegen-rt-natives-windo
ws-i586.jar!/
Exception in thread "Animation Thread" java.lang.UnsatisfiedLinkError: Can't loa
d library: C:\Users\Joe\Desktop\navx-utilities\navXMXPUI\application.windows64\g
luegen-rt.dll
        at java.lang.ClassLoader.loadLibrary(Unknown Source)
        at java.lang.Runtime.load0(Unknown Source)
        at java.lang.System.load(Unknown Source)
        at com.jogamp.common.jvm.JNILibLoaderBase.loadLibraryInternal(JNILibLoad
erBase.java:551)
        at com.jogamp.common.jvm.JNILibLoaderBase.access$000(JNILibLoaderBase.ja
va:64)
        at com.jogamp.common.jvm.JNILibLoaderBase$DefaultAction.loadLibrary(JNIL
ibLoaderBase.java:96)
        at com.jogamp.common.jvm.JNILibLoaderBase.loadLibrary(JNILibLoaderBase.j
ava:414)
        at com.jogamp.common.os.DynamicLibraryBundle$GlueJNILibLoader.loadLibrar
y(DynamicLibraryBundle.java:388)
        at com.jogamp.common.os.Platform$1.run(Platform.java:203)
        at java.security.AccessController.doPrivileged(Native Method)
        at com.jogamp.common.os.Platform.<clinit>(Platform.java:173)
        at javax.media.opengl.GLProfile.<clinit>(GLProfile.java:82)
        at processing.opengl.PJOGL.initSurface(PJOGL.java:238)
        at processing.opengl.PGraphicsOpenGL.initPrimary(PGraphicsOpenGL.java:59
88)
        at processing.opengl.PGraphicsOpenGL.requestDraw(PGraphicsOpenGL.java:16
00)
        at processing.core.PApplet.run(PApplet.java:2177)
        at java.lang.Thread.run(Unknown Source)
If I just try to run the .exe file, it's just a blank, white window. I've tried downloading the NavX_Utilities different times and I've tried this on 3 different laptops (granted, all running 64-bit Win8.1) with no success.
Thanks!
  #78   Spotlight this post!
Unread 01-21-2015, 01:58 AM
Software Mentor
AKA: Scott Libert
Talking Re: ANNOUNCING: navX MXP Robotics Navigation Sensor
Code:
ws-i586.jar!/
luegen-rt.dll
erBase.java:551)
va:64)
ava:414)
88)
00)
Thanks!
Ok, that helps. To help narrow things down, what version of Java is installed?
Also, you might try installing the processing IDE, using the instructions at the bottom of this page: https://code.google.com/p/navx-mxp/wiki/navXMXPUI
  #79   Spotlight this post!
Unread 01-21-2015, 02:02 AM
jojoguy10's Avatar
AKA: Joe Kelly
Rookie Year: 2010
I have Java 8 Update 31 installed on my main computer.
I have the Processing IDE installed (v2.2.1) When I try to run the navXMXPUI.pde, it says:
Code:
No library found for com.kauailabs.navx_mxp
Libraries must be installed in a folder named 'libraries' inside the 'sketchbook' folder.
  #80   Spotlight this post!
Unread 01-21-2015, 02:08 AM
Software Mentor
AKA: Scott Libert
Code:
We may have an issue with Java 8 (we tested with Java 7).
You'll need processing IDE v 2.1.
Also the sketch folder in the processing IDE needs to be set to point to the directory that has the navXMXPUI.pde file in it.
  #81   Spotlight this post!
Unread 01-21-2015, 10:48 AM
ayeckley's Avatar
ayeckley ayeckley is offline
AKA: Alex Yeckley
FRC #2252 (Mavericks)
Rookie Year: 2007
ayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond repute
Originally Posted by bmammen View Post
no matter what values we use for PID, the bot rotates to the angle and constantly shakes back and forth trying to reach the exact angle.
That sounds like a classic case of the Proportional gain being set too high. Keep in mind that it might require surprisingly small values, depending on your exact implementation. If you haven't already, the recommended PID tuning process starts with the I and D gains set to zero and the P gain set to a very low value. If you still get oscillation, then it is probably(*) necessary to decrease the P gain. If the robot "under-turns", then increase the gain incrementally. Generally speaking, once tuning is complete the P gain value should be just below the point at which you get oscillation. This can be very tricky with drives that have to overcome a large amount of stiction (static friction) in their drive systems (Mechanum drives are a good example) and robots that have relatively high angular moments of inertia (all of them?). It's highly unlikely that the navX unit is the source of the problem. You'll get very different behaviors if your robot is on a hard floor vs. carpet; try to use the most-FRC-realistic surface you can obtain.
* You might also get the symptoms you've described if there is some binding or other non-uniform drag in your drivetrain.
  #82   Spotlight this post!
Unread 01-21-2015, 10:55 AM
jojoguy10's Avatar
AKA: Joe Kelly
Rookie Year: 2010
Rolling back to Java 7 worked! Thanks!
  #83   Spotlight this post!
Unread 01-21-2015, 11:02 AM
bmammen's Avatar
bmammen bmammen is offline
AKA: Brent Mammen
FRC #5801 (Inspire)
Rookie Year: 2014
bmammen is an unknown quantity at this point
We started with the P value but no matter what its set at (low or high) the turn is still at the same velocity - it does hit the angle though before gyrating back and forth trying to reach accuracy. We've also tried changing the % SetTolerance which yields no change. It must be something with the way we are handing the PID output. Thanks for the suggestions.
  #84   Spotlight this post!
Unread 01-21-2015, 11:04 AM
Software Mentor
AKA: Scott Libert
Great to hear, congratulations.
Did a little research on the error message re: the missing file; it looks like the previous Java system thought it was 32 bits, so perhaps previously the 32-bit version of Java 8 was installed. We will do some testing with Java 8 and the navXMXPUI to try to get this sorted out.
  #85   Spotlight this post!
Unread 01-21-2015, 11:19 AM
jojoguy10's Avatar
AKA: Joe Kelly
Rookie Year: 2010
Hmmmm...I guess that's possible.
Thanks again for the help. The NavX is VERY responsive at 60Hz! It's awesome!
  #86   Spotlight this post!
Unread 01-21-2015, 11:23 AM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
What P values were you using for "low" and "high"?
It sounds to me like you need to set the P constant lower yet. Remember that it's using the error in robot heading and turning that into a motor command. Motor values are between -1 and 1, and you probably want it to go to less than ten percent power when you're within several degrees of the target. I'd try a Kp of 0.01 to start with and go from there.
  #87   Spotlight this post!
Unread 01-21-2015, 08:13 PM
ayeckley's Avatar
AKA: Alex Yeckley
Rookie Year: 2007
Scott,
I too am having difficulty running the UI. If I execute navXMXPUI.bat (edited as specified to point to COM4, which is where the ST VCP is connected), I get an error "Could not find or load main class NAVXMXPUI". I am able to run navXConfig (setup.exe) with no issues which leads me to believe both the PC and navX hardware are configured properly.
I'm using Win 7 (64 bit), and have Java 1.7 runtime enabled under User settings (1.8 is also installed, but I have disabled it). I've also installed Processing 2.2.1 (BTW, 2.1 is not listed as a downloadable release) and have merged the UI "processing" directory to the [user]\Documents\Processing location. I can open the Sketch successfully however when I attempt to compile it I get the same library errors as a previous poster reported (no library found for com.kauailabs etc.). When I "Show Sketch Folder", the navXMXPUI folder (and its subfolders) is displayed as one would expect.
Where have I gone wrong? I suspect it's something in my Java configuration.
Last edited by ayeckley : 01-21-2015 at 08:33 PM. Reason: Update: discovered that the library needs to go under [user]/Documents/Processing, not just [user]/Processing
  #88   Spotlight this post!
Unread 01-21-2015, 08:33 PM
Software Mentor
AKA: Scott Libert
Scott,
I too am having difficulty running the UI. If I execute (from a Command window) navXMXPUI.exe, nothing happens and no errors are generated. If I execute navXMXPUI.bat (edited as specified to point to COM4, which is where the ST VCP is connected), I get an error "Could not find or load main class NAVXMXPUI". I am able to run navXConfig (setup.exe) with no issues which leads me to believe both the PC and navX hardware are configured properly.
I'm using Win 7 (64 bit), and have Java 1.7 runtime enabled under User settings (1.8 is also installed, but I have disabled it). I've also installed Processing 2.2.1 (2.1 is not listed as a downloadable release) and have copied the "processing" directory to the specified location. I am not able to "Open the Processing IDE and then open the navXMXPUI sketch via the "File->Sketchbook menu" because there are no selections available ("Empty Sketchbook" appears, greyed-out). I can open the .pde successfully using the File/Open dialog, however when I attempt to compile it I get the same library errors as a previous poster reported (no library found for com.kauailabs etc.). When I "Show Sketch Folder", the navXMXPUI folder (and its subfolders) is displayed as one would expect.
Building the navXMXPUI with the Processing IDE 2.2 has an issue we haven't fixed yet, I think that's causing your issue.
The pre-built binary in the navxmxpui\application.windows64 directory should work on 64-bit windows if java 1.7 is installed, it's built with processing IDE 2.1. Looks like the link to the 2.1 IDE has been removed.
  #89   Spotlight this post!
Unread 01-21-2015, 08:55 PM
Software Mentor
AKA: Scott Libert
Until we get the Processing IDE 2.2 and Java 8 working w/the navX MXP UI, the 2.1 installer for 64-bit windows version of processing 2.1 is temporarily available here.
  #90   Spotlight this post!
Unread 01-21-2015, 09:05 PM
ayeckley's Avatar
AKA: Alex Yeckley
Rookie Year: 2007
Update: I've removed everything related to the UI source code (including Processing 2) and am focusing on trying to get the precompiled version to work.
I did discover that my rollback to JRE1.7 was not completely successful despite what the Configure JAVA tool was telling me. By doing the on-line JAVA verification I discovered that 1.7 was being blocked as a security threat. I was able to authorize it, and am now getting quite different (still unsuccessful) results:
Catched FileNotFoundException: C:\Users\ayeckley\Downloads\navx-utilities\navXMXPUI\application.windows64\lib\glue gen-rt-natives-windows-i586.jar (The system cannot find the file specified)<snip>
In the .zip I just downloaded there was a "gluegen-rt-natives-windows-amd64.jar" but not a "gluegen-rt-natives-windows-i586.jar". Is this the smoking gun? I've verified that I'm running Win 7 64 bit, on an Intel processor (not an AMD).
